It is currently Sat Jun 13, 2026 8:02 am
 Post subject: axle conversion
PostPosted: Thu Mar 29, 2007 8:49 pm
how hard is it to just get rid of the front independant and use matching axles. i want to put a straight axle conversion but use my trany and everything else. i know pitman arm and drive shafts but like how hard
PostPosted: Thu Apr 05, 2007 2:09 pm
the "getting rid of it" is the easy part. it'll take some time, if you have everything and know what you're doing (aside from building driveshafts) it should only take a weekend or two of hardcore cutting/fabbing/welding
"I'll take 'The Rapist' for $1200 Alex..."
"That's 'Therapist' Mr. Connery"
PostPosted: Thu Apr 05, 2007 6:36 pm
i have someone that will do driveshafts, what springs and axles would be recomended?
PostPosted: Wed Apr 11, 2007 4:37 pm
so you are going to keep the stock drivetrain... i would suggest maybe a toyota axle(prolly the best in stock form aside from Barfs :P uhh i mean Birfs maybe a D30 or D44. as far as springs go you have MANY MANY options,......did i mention many? it really depends on what you're looking for. are you looking for soft with lots of flex, stiff for jsut lift and appearance or a mix of both on and offroad capabilities (DD action)??? as with all this stuff comes thinking ahead. something of which im getting better with as the projects cycle. but one thing you'll wanna think about is steering, are you wanting the J-arm(OK not real flex friendly) "Y" (Good) crossover steering(better) or crossover high steering (best) i can show you pics for examples of this stuff and maybe show you what i've done. to help you better decide what route you want to actually take. 8)
PostPosted: Wed Apr 11, 2007 6:56 pm
picts would help a lot
PostPosted: Fri Apr 13, 2007 12:33 am
Go here http://toyotalinks.com/ and look around for solid axle swaps. I know it's all about Toyotas, but it should give you an idea of what you are in for. In all reality, you will be doing all the same things to your LUV, you'll just be using different measurements! :D
I'm partial to Toy axles myself. Hell if you could find a donor Toy you could swap out the entire drive train ( engine, tranny/t-case, and axles) this would give you a bunch more power, and if you went 82 or newer, a 5-speed!
Looking for that special LUV.
 Post subject: Re: axle conversion
PostPosted: Thu Oct 09, 2008 3:22 pm
post resurrector
I have an '80 with a dana 60 front and a 14 bolt rear with 8in lift half ton springs snd it does great. (big block) 8)
'80 luv 4wd 6.0 vortec hurst 4spd process of lifting
'69 f-100 4wd 14" lift and 44s
'03 f-150 4dr 4wd daily
BOOMER SOONER!!!
Users browsing this forum: Baidu [Spider] and 8 guests
