It is currently Wed Jul 01, 2026 7:15 am
 Post subject: wheels?
PostPosted: Fri Apr 25, 2003 9:46 am
has any one put 16' wheels on a luv? i didn't know if they will work in the front with the turning radius, will they rub? i mean wheels off like a new s-10 xtreme or a late 90's camaro. i want a different look if they will fit. any help appreciated.
thanks
PostPosted: Fri Apr 25, 2003 12:36 pm
I put my freinds wheels off his T/A up in the front and the wheel had plenty of clearance. The tires were a 60 series and they rubbed. If you used a tire with a shorter sidewall it would work. My 50 series looked like they would clear just fine. Or if you want to start dragging your cross member and collecting road reflecters you could put a 40 series on there.
PostPosted: Fri Apr 25, 2003 1:09 pm
thanks happy that is good to know for future reference
thanks
PostPosted: Sun Apr 27, 2003 1:28 pm
I run 205/70/16 on isuzu trooper rims on my truck and there is no rubbing. The trooper rims are just the right dish.
PostPosted: Thu May 01, 2003 11:48 pm
OG Lifer
Are all luvs 6 lug? I need to go to a 15 in. rim to mount taller tires on. A good set of 35 in boggers would do nicely. I may just get crazy and build it with deuce and a half axles, about 18 inches of lift, and a set of 44 in boggers. With the 2 1/2 ton axles, and the gear ratio of about 6.50 to 1, I may also keep the four banger just to piss people off.
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Fri May 02, 2003 7:36 am
I m not an expert, but I do beleive all were six lug.
Users browsing this forum: Baidu [Spider] and 27 guests
