It is currently Sun Dec 21, 2025 6:38 pm
 Post subject: 10" Wheels
PostPosted: Mon Mar 26, 2007 9:54 pm
Does any of you have 10" wheels mounted on the factory rear end of a luv? If you do, what is the backspacing. Please post pictures. If not, do you have 8" wheels with factory rear end? What's your backspacing? I want the widest wheel possible without the wheel sticking out much. Actually I'd like it pretty flush with the fender. Thanks!
LOUISIANA BOY HERE!
PostPosted: Tue Mar 27, 2007 1:16 am
15"x8" Rim, 4.5" Backspacing with a 275/50/r15 tire. S10 rear end though. Sorry but should'nt matter much as long as you got a 6 lug rim because both rear ends are the same width. Not sure if you can tell from the pic. much but the tire is pretty flush with the bed. Hope it helps.
PostPosted: Tue Mar 27, 2007 1:46 am
Maybe this will help
http://forums.luvtruck.com/viewtopic.ph ... 45&start=0
PostPosted: Tue Mar 27, 2007 8:20 am
I have 10 inch with wide with 4 inch backspace and my MT's stick out 4 inches past the fender well.
Tread width approximately 12 inches.
My avatar pic has 8 inch wide 4 inch backspace and 265 50 15's
They are about 1 inch out.
