It is currently Wed Mar 18, 2026 11:32 pm
PostPosted: Sun Mar 18, 2007 4:11 pm
The first thing i know for fact is that you can go from g180(1.8l) to g200(2.0l), other options include 2.3l(4zd1) and 2.6l(4ze1), and if am not mistaken then the parts of these engines can be interchanged(head/block/manifolds), this also includes me theory on using the 2.6 EFI intake for a dual carb setup(the lower section has 2 openings that appear as if they could be modified to put dual carbs on it). I dont know much about the transmitions, or rear-ends that can be added to them, and any more extensive information on these would be greatly appreciated, once i have all this info and feel the info i already have is complete i am going to write up a page on my website that is divoted to to the 4cyl upgrades complete with total defiinitions and pictures/drawings. So as i said any and all info anyone has on this sublect would be great....
Thanks,
-Dustinicus
 Post subject: .
PostPosted: Sun Mar 18, 2007 4:50 pm
Just outta curiosity...
how does a Luv 1.8 handle dual carbs? Fisrst off, I'm certainly not a 100% gearhead, it just seems all that fuel would drown the little 4 banger?
FIAA: Color Guard
PostPosted: Sun Mar 18, 2007 8:11 pm
Do a mild portjob to the heads, add headers and msd ignition, and you should be fine.
LOUISIANA BOY HERE!
PostPosted: Sun Mar 18, 2007 8:32 pm
they run alot of them down under with the duels...
PostPosted: Sun Mar 18, 2007 8:39 pm
now that is a clean engine.
PostPosted: Sun Mar 18, 2007 10:17 pm
Swap Specialist Mod
I WANT THAT BELT SETUP!!! that is freakin badass right there!!
PostPosted: Sun Mar 18, 2007 10:54 pm
they are about $200 and sound like a supercharger, been tring to get one for less but they dont show up much
PostPosted: Tue Mar 20, 2007 12:12 am
Do you know where I could get one of those belt drives new?
1975 V8 Luv
1980 Bagged Luv
 Post subject: back to the engines
PostPosted: Thu Mar 22, 2007 1:46 am
so as i was saying, i want to get all the information that anyone has on the upgrade/replacement of the g180 i know the 2.6l will fit in there, but i wanna know where exactly to get it out of, and and other info people have on such things as a turbo MPI system, i am working on a complete guide to engine upgrades, and if successfull the i plan on building this upgrade onto my truck, then once i have all the bug worked out im going to publish it(kinda) and put it out in the world via personal website, cardomain, and luvtruck of coarse so please any and all info on engine parts lists, upgrades, exact transmitions, rear-ends (that will fit without chopping and tweaking the h311 out of the stock mounting places)
thanks again
-Dustinicus
PostPosted: Thu Mar 22, 2007 1:57 am
sorry newbie, were easily distracted by shinney objects, especially if their luvs, about your question theres plenty of reading to do on this site, most everything you can do to a luv is right here.......might wanna try reading "the sticky"
and a bright imagination would greatly help too. :smt033
PostPosted: Thu Mar 22, 2007 2:19 am
This thread was about 15 threads below yours on the same page, maybe it will help.
http://forums.luvtruck.com/viewtopic.php?t=12797
 Post subject: thank you
PostPosted: Thu Mar 22, 2007 4:32 pm
so thank you all for your input i was jsut looking for some confermation, and i appreciate all the info now that i have what i am looking for i will get started on my complete 4cyl guide, and when its done i shall share it with the world... if any one has any more input then please feel free to email me thedustincc(at)hotmail(dot)com
 Post subject: .
PostPosted: Thu Mar 22, 2007 5:13 pm
May want to include a small section on eliminating the crappy points or contact breaker ignition. Pertronix & Crane offer severl nice solid state options available for just about any engine. From what I've read, it's the best way to go.
I am running on MSD 5200 + points for now. Will add a Pertronix set next month or after I burn up this new set of points, whichever comes first :)
FIAA: Color Guard
PostPosted: Thu Mar 22, 2007 6:37 pm
You might burn up points everytime you start your truck, but you look damn nice doing it!! :lol:
Have you thought about grabbin' a dizzy out of an 82 LUV? There are no points in them. I know there are a few threads about doing this swap.
Looking for that special LUV.
 Post subject: .
PostPosted: Thu Mar 22, 2007 6:59 pm
Hmm...no I hadn't considered that option, there's supposed to be a large pick n pull lot in Abilene, near me. May be visiting there soon.
Good idea, thanks troop.
FIAA: Color Guard
PostPosted: Fri Mar 23, 2007 1:29 am
I swapped a 5 speed trans out of a 1990 isuzu spacecab with a 2.6 in my '78 without having to do any cutting all I had to do was get a new driveshaft made.
The bellhousing pattern on the 1.8 2.0 2.3 and 2.6 are the same. There are differences between them like hydraulic and cable operated clutch setups but they can be converted easily from hydraulic to cable and vice versa.
Rear axles out of S10 and isuzu pickups are bolt ins.
The driveshaft configuration for each rear axle is different though so a custom driveshaft would have to be made.
1975 V8 Luv
1980 Bagged Luv
