 Post subject: Mustang suspension?
PostPosted: Fri Mar 17, 2006 10:41 am
What years of mustang 2 suspension are best for the swap. Does anyone have pics of what there luv looks like after the swap
PostPosted: Fri Mar 17, 2006 10:50 am
check out Scott Howard's pics in the gallery... he did a mustang 2 front end with his big block setup
PostPosted: Sat Mar 18, 2006 11:54 pm
Japanese Redneck
the LUV suspension is pretty decent. any reason why you want to ditch it?
what part of NM are you from?
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Sun Mar 19, 2006 10:10 pm
well iv torn the truck down to frame and am trying to look at all the options i can do. once i build the truck back up,i dont wanna modify anything again. plus im still thinking of going big block
im from the Albuquerque and los lunas area
PostPosted: Mon Mar 20, 2006 11:41 pm
Japanese Redneck
the components of a stock Mustang II front end weigh more than a stock LUV front end. you do get the benefit of a nice rack and pinion steering and you can lighten them up a lot if you put chrome moly tubular A arms, coil overs and an aftermarket x-member but the LUV front end is a proven strong and good performing front end and.... best of all its already there. just something to consider.
Cool. I have a friend that lives in Clovis, NM so whenever i see somebody from NM i have to ask.
1978 LUV Truck 2WD
3.70 Ford 9
28x10 Goodyears
PostPosted: Tue Mar 21, 2006 12:15 am
Put some coil overs on and ditch the bars. Do a search on coil over subject. Its worth checking out.
