It is currently Mon May 25, 2026 10:07 pm
for my tailgate sould i....
Poll ended at Sun Jan 29, 2006 9:12 pm
french my plate 63%  63%  [ 5 ]
make the "CHEVROLET" crooked 38%  38%  [ 3 ]
Total votes : 8
 Post subject: finished choppin my bed
PostPosted: Sun Jan 22, 2006 9:12 pm
today i got my bed put back together and if you look close at the front you can see how the bed has changed.
1-2 it's not new, 3-4 shave the door, 5-6 learn some trix, 7-8 make it scrape!, 9-10 show your friend!
Last edited by twist_of_fait on Mon Jan 23, 2006 11:14 pm, edited 2 times in total.
PostPosted: Sun Jan 22, 2006 9:13 pm
yeah you can really tell you've cut it down a bit... looking good though
PostPosted: Sun Jan 22, 2006 10:12 pm
can you make chevrolet crooked and french the plate or is there not enough room?
2002 Lexus RX300
1998 Honda Accord
1977 Chevy Crew Cab Dually
1954 Ford F100
http://www.yvtruckclub.com/forum
PostPosted: Mon Jan 23, 2006 12:33 am
it would be to clutered
PostPosted: Mon Jan 23, 2006 4:09 am
Swap Specialist Mod
it looks alot better with the bed centered up like that. as for the tailgate mod, i sould just leave it as it is. they looks good from the factory. but its up to you.
PostPosted: Mon Jan 23, 2006 11:15 pm
shot of my truck laid out....(needs a body drop bad!)
frame on the gound
Image[/img]
PostPosted: Tue Jan 24, 2006 12:16 am
Swap Specialist Mod
lookin pretty good man. your right though, it does need a body drop. aqnd maybe some lower profile tire. not a whole lot thinner, but just a wee bit.
PostPosted: Tue Jan 24, 2006 12:37 pm
yeah i've been thinking about gettin some 50 series(i've got 55's) but then i wount tuck as much rim. that and i wont be getting any lower buy switching tires. so im holding out till' there's a tire sale....i cant find any used one any where! i've tride all the tire shops and junk yards....even ebay!
PostPosted: Tue Jan 24, 2006 5:31 pm
Damn those wheels look good on there!
PostPosted: Tue Jan 24, 2006 5:48 pm
Looks like the bed could come up a tad, the body line doesn't quite line up just right. The chop looks pretty good though, but cutting out at the front of the bed kinda messes with the line down from the cab flowing into the bed. Only other way to do it would have been slicing a section from the middle of the bed between the fender and the upswoop of the line on the side of the bed. That would have meant many more hours of cutting/welding and it would all have been exposed so it would have to be perfect.
That thing is damn low, looks like you could pick the tires up off the ground the way it sits. Body drop it, put some magnesium pads on the low points of the frame, and it would put on one hell of a sparks show. :twisted: Makes for a great theft deterrant too, even a wrecker would be hard pressed to drag it off with the frame on the ground. :lol:
PostPosted: Tue Jan 24, 2006 10:30 pm
hey twist how much did your air bag sus. cost you if you dont mind me askin? and was it very difficult to put on? oh and one more question was all your suspension stock before you put it on?
PostPosted: Tue Jan 24, 2006 11:25 pm
Have you seen his cardomain page? If not, click the www under his sig. It looks like he made a 4link with a C notch to drop it even further. I'm sure he can explain things better though.
2002 Lexus RX300
1998 Honda Accord
1954 Ford F100
PostPosted: Wed Jan 25, 2006 1:02 pm
yeah the bed still needs to be shimmed. as for the suspension it was all stock. just to remember you blove i am on a s10 blazer frame. anyways i'll make a list really quick!
1 5 gal. tank $50
4 1/2" valves $150
4 2500lb. bags $200
1 ajustable pressure switch $25
1 viair 380c compressor $164(should have got a 400c or 450c)
2 switches $10
fittings $20
12' 5/8" airline $30
10' 1/2" airline $15
DRAGGIN YOUR LUV THE FIRST TIME! PRICELESS :D
