It is currently Tue May 26, 2026 12:13 am
 Post subject: Centerlink Help?
PostPosted: Sun Mar 27, 2005 8:37 pm
Trying to remove the pitman arm from the centerlink.. Unfortunately, once the pin is out of the retaining nut, the bolt spins with it. The other end of the bolt on the back side of the center link end seems to be covered by some sort of cap. My question is, how do I get that bolt out of there so I can take the pitman arm off? My steering box is fried
PostPosted: Thu Mar 31, 2005 6:55 pm
Ok, I'm stumped. After my problem mentioned earlier, I went back to trying to get the pitman arm off the splines. Went out and bought a pully removing tool and tried it. It's too weak to do the job. Even after a full coat of WD-40 and several attempts, the tool would apply plenty of pressure, then one of the arms would just slip off. I've got to change out this gearbox, but not having any luck. Any ideas?
PostPosted: Sat Apr 02, 2005 9:37 am
Hi Darc,
Yep, I had to pull mines off and it was a bear. I ran into the same problems you are experiencing. I measured the pitman arms width and searched for a "good" pitman arm pulley that had he necessary jaw gap so it wouldn't slip. It took a while to find one. I would recommend to get a good quality pulley with a full replacement guaranty, I actually broke one using a cheater bar on my wrench.
I placed the pulley on the pitman and put some heavy duty pressure on it and took my torch and heat up the joint area and it broke free.
I hope this helps
Kaneguy
PostPosted: Sat Apr 02, 2005 11:15 am
Thanks man! Might have to go out and get a better torch lol. Where did you find that specific puller, if you don't mind me asking? I've been worrying about breaking that one, and the warranty is lifetime, but it has one of those "intended use" clauses. Cheater bar breakage probably isn't covered
