It is currently Mon May 25, 2026 7:37 am
 Post subject: MONZA ROTORS
PostPosted: Fri Jul 02, 2004 11:24 pm
FYI
I found out that Monza rotors will work just like Vega's on the disk brake swap.A fellow LUV owner here online confirmed it.I picked up a new set for $20 on e-Bay.
 Post subject: Rotors
PostPosted: Sat Jul 03, 2004 4:12 pm
Are the Monza 5 lug? Or do you stillhave to re-drill?
PostPosted: Sat Oct 16, 2004 1:09 pm
Finally,put the chevy monza rotors on.Bored to fit LUV bearings, bore depth 1 1/8 on front and rear, rotors cut to .700 thick, 1/8th thick spacer used behind rear bearings on the spindle.MOROSO 2 7/8 long racing studs with .480 knurl.
Image[/url]
Last edited by 671SuperchargedLUV on Sat Oct 23, 2004 11:15 am, edited 1 time in total.
PostPosted: Mon Oct 18, 2004 10:04 am
Well thats cool, but what about the calipers? Do you use the monza calipers and brackets?
PostPosted: Mon Oct 18, 2004 10:59 am
you can use the luv calipers and have to shave a little bit off of them, but they will work.
see more in my www button below.
03Cobra
PostPosted: Tue Oct 19, 2004 6:33 pm
That is correct, I used the stock calipers just like he explained in the swap info.Precision Brakes wanted $1800 for a one off four piston disc brake setup for LUV.They said they would build them for $1200 if enough people ordered them at the same time.The swap is far less than that and well worth it.
Thanks for all the help!!!!
PostPosted: Wed Oct 20, 2004 4:13 am
Is it me, or do those studs look really damn long :?
PostPosted: Wed Oct 20, 2004 5:07 am
that is what SHE said! HAHA!
03Cobra
PostPosted: Sat Oct 23, 2004 11:27 am
I'am also building this LUV to be rule book legal for drag racing.That's why I have the extra long racing studs.
PostPosted: Sat Oct 23, 2004 8:17 pm
Ohh!! Now I see :oops:
