 Post subject: dash caps
PostPosted: Sun Jun 13, 2004 12:11 pm
what is a dash cap and how do you install it.
kevin
PostPosted: Sun Jun 13, 2004 12:18 pm
a dash cap is just the top of the dash.
you have to cut the top off then glue the new top on 8)
PostPosted: Sun Jun 13, 2004 6:02 pm
I just got one a couple months ago from JC Whitney. All you do is apply the supplied glue on the original dash surface and lay the cap over it. Dont have to remove any material as long as your original pad isnt lifting or curling up. The cap sort of raps around that top edge of the dash on the front. I havent installed mine permanently yet as Im still indecisive about smoothing and painting it or rapping some fabric over it. Or just leaving it black and gluing it in. For the money I think its a great idea. Hell of alot cheaper and easier than buying and installing the whole repro. pad also.
PostPosted: Sun Jun 13, 2004 8:55 pm
Could you post some pics cause im debating geting one.
Thanks
`79 LUV 2WD Stocky
`80 LUV 4WD Stocky
PostPosted: Mon Jun 14, 2004 8:42 pm
I would if I could. Before I got one I asked for photos here. Do a search for them. I think I got two or three replies.
PostPosted: Thu Jun 17, 2004 8:41 pm
My dash cap is terrible, right in the middle on top the thing is curling up and half of it is gone. What is the best and cheapest way to get it lookin good agin? I found a sight that has dash caps, but im not sure i can use it to repair mine. http://www.topsonline.com/en-us/dept_237.html
Another ? My '75 dash is all one piece and the cap i found is just teh top half what do i do?
PostPosted: Thu Jun 17, 2004 9:35 pm
You need to cut or scrape the parts of the dash that are sticking up before you cap it. I would think thats why they are called caps because they just cover the top.
PostPosted: Fri Jun 18, 2004 11:28 am
well it sounds easy enough i just wish i acted faster there was on ebay for like 20$. but oh well
kevin
PostPosted: Fri Jun 18, 2004 10:38 pm
So this new dash cap goes over the old remains instead of replaceing it? That's ok and all but what am I supposed to do about the bottom half since it is faded pretty bad and there will be a huge color differnce?
PostPosted: Sat Jun 19, 2004 7:06 pm
Go to your local parts store and pick up a can of vynil dye.
PostPosted: Sat Jun 19, 2004 10:57 pm
Would you happen to know where I could get a dash cap cheap?
Thanks
PostPosted: Sun Jun 20, 2004 6:00 pm
Ive seen them on ebay for about $20 cheaper than I paid at JC Whitney.
 Post subject: cap vs cover
PostPosted: Sun Jun 20, 2004 7:06 pm
At a junkyard I saw a cover that fit over the top of the dash, kinda like a car cover to a car. A good portion of my dash near the windsheild is curling up. I wonder if I would have to take out some of that and then somehow add bracing in there to support the cap.
PostPosted: Mon Jun 21, 2004 6:06 am
Yes. At the moment part of that area on my dash is missing already. And the egdes were sticking up until I glued them down. Now I have to place something in the void as you can see the hole from the outside with the dash cap on. Thinking Ill get some of that florist/craft foam and widdle it down to shape.
PostPosted: Tue Jun 22, 2004 8:34 pm
So i found a dash cap at http://www.topsonline.com/en-us/dept_237.html
could you look to see if this would work for me? Will I need to remove the old dash to install this one or will this one fit over the old one? And you said i could get vynil dye for the bottom half. Have you used dye before and will it have good results?
PostPosted: Tue Jun 22, 2004 9:22 pm
Yes that will work. It looks like the exact same one that I paid more for. And yes Ive used dyes for about 14 years while detailing cars. We use it for carpets mostly, but ocasionaly a door panel or seat. Just think of it as regular spray paint in a can. Use a couple light coats and its all good. And dont be cheap. It only costs a couple bucks more for a good quality dye. Mar Hyde is good and I think Rustolium has a dye out now also. Just stay away from store brand ones that will just end up peeling off in a few years.
PostPosted: Wed Jun 23, 2004 5:26 pm
Thaks for your answer, but will this one fit over the old dash or will I need to remove the old one to install the new one?
PostPosted: Thu Jun 24, 2004 9:11 am
It goes right over the old one.
