It is currently Tue May 26, 2026 12:13 am
 Post subject: welding question?
PostPosted: Mon Feb 07, 2011 10:16 am
when welding on the axel (4-link tabs) do u guys drain the fluid or weld with it in their? what prep work do u use?
 Post subject: Re: welding question?
PostPosted: Mon Feb 07, 2011 5:44 pm
When I did mine it was in a jig.
PostPosted: Mon Feb 07, 2011 11:12 pm
Just draining is not gonna get all that heavy gear oil out. As long as the case has a vent I would think it should be OK.
I know I have welded shock and spring mounts on many and never had a problem. All it can do is catch fire :wink: just keep a good approved extinguisher handy.
PostPosted: Tue Feb 08, 2011 12:27 am
One suggestion, get some regular medium bath towels soak them in water and wrap the axle with them right next to where you are welding, keep these wet! Weld slow and even, a lttle at a time is better than warping the housing or burning up seals inside the rear housing by to much heat and welding at the same time. I don't think you will effect the fluid in the rear end.
PostPosted: Tue Feb 08, 2011 12:05 pm
ok got it thanks everyone!!!!!
PostPosted: Tue Feb 08, 2011 1:55 pm
Just welding the brackets on you wont have a problem. You didnt say what kind of rear but I know 9" axle tubes are surprisingly thick. I welded mine on under the truck and I really put alot of heat in it and the end flanges where the seals were was not even warm, so I say weld away my friend. Oh, yeah I didnt drain the fluid either, and no fire.
[img][IMG]http://i962.photobucket.com/albums/ae108/FedMoore/thIMG_0358.jpg[/img][/img]
PostPosted: Thu Feb 10, 2011 9:22 am
its a 88 yota axel. thanks for the help should all go smoothly now.
