It is currently Tue May 26, 2026 1:37 am
 Post subject: line lock..
PostPosted: Sun Jan 09, 2011 6:44 pm
Location: Colonial Beach VA. If i am not home or at the track then I am probably at HOOTERS!
As you know luvs have 2 brake lines coming off the m/c to each front wheel. is it possible to t these into one in the line lock inlet and then split them again on the outlet of will l have the truck pull madly to one side or the other on the big end..not trying to experience this at 120+ mph...
74 LUV 355 Bracket Car
WANTED DEAD OR ALIVE 68-74 NOVAS
TOO MUCH IS NOT ENOUGH!!!!!!!!!!!!!!
 Post subject: Re: line lock..
PostPosted: Sun Jan 09, 2011 8:46 pm
Pascal's law states that pressure is equal in all directions anywhere in a fluid system. That means it should work. No way to be sure unless somebody has tried ti.
PostPosted: Sun Jan 09, 2011 8:52 pm
One line off the MC to the line loc, then tee out the line loc to each wheel...
PostPosted: Mon Jan 10, 2011 8:58 pm
yea dont think mine has 2 off the mc to each front wheel....mine is done ^^^^^
PostPosted: Mon Jan 10, 2011 9:47 pm
PM LUVTRKR, the 76 I sold him has a line lock installed. He is cool, I am sure he would send you a picture.
PostPosted: Tue Jan 11, 2011 11:07 am
i know the international truck from the 50's used a single line to a 4 way block that also housed a pressure switch to turn on the brake lights.
if it works in the past...
PostPosted: Sun Jan 16, 2011 8:01 am
So where does the proportioning valve fit in. Have my lock hooked up but don't think it is right.
