It is currently Mon May 25, 2026 11:24 pm
PostPosted: Sun Jan 10, 2010 8:21 pm
Has anyone used one of the fiberglass hoods made by FeatherCarbon out of Suffolk VA. ? Look like race weight only and I was curios about the fit and quality. Thanks
PostPosted: Mon Jan 11, 2010 8:43 am
I wish they made a hood without the cowl, but $700 is expensive.
PostPosted: Mon Jan 11, 2010 2:51 pm
Yeah, I'm looking at the fiberglass cowl hood. I can't afford the carbon fiber version.
PostPosted: Mon Jan 11, 2010 3:29 pm
Please buy one and give us some feedback, I am wanting some one else to go first...
PostPosted: Mon Jan 11, 2010 3:58 pm
I just got off the phone with them. I'm going up there on friday to get one. I'll tell you about it when I get back. You ready for those a-arms? :D
PostPosted: Mon Jan 11, 2010 4:23 pm
yes...
PostPosted: Mon Jan 11, 2010 8:34 pm
My painter is using the steel hood and fiberglassing a cowl scoop into it. I will take some pics on how it turns out. If it ends up cracking out guess I will have to bite the bullet and get one of these....
PostPosted: Mon Jan 11, 2010 9:24 pm
I am waiting for ctmandu to make a race hood out of fiberglass.
PostPosted: Mon Jan 11, 2010 9:26 pm
and soon... will start everything back up in Feb... sorry taking so long
PostPosted: Mon Jan 11, 2010 9:33 pm
Not a problem here. I probably won't be racing my truck right away as I will be getting the daughter started. You still got a bumper for me yet?
PostPosted: Mon Jan 11, 2010 10:01 pm
yes bumper here and ready to go
PostPosted: Mon Jan 11, 2010 10:10 pm
:smt023
PostPosted: Thu Jan 14, 2010 10:10 pm
my friend got a carbon fiber hood for his talon eagle but the finish on the carbon fiber fades and gets cloudy i wont buy one
75-luv mikado-V8 350 soon
PostPosted: Thu Jan 14, 2010 10:14 pm
can you paint carbon fiber?
PostPosted: Thu Jan 14, 2010 11:55 pm
Yea I would think...even a clear will help
PostPosted: Fri Jan 15, 2010 12:24 pm
If the hood is fabricated with epoxy, you can mix some epoxy, thin it out with a little MEKP, and spray the hood. (If the hood has a fiberglass matrix, it can still be done with epoxy but you must spray very light coats and spray again when the first coat become tacky.) DO NOT APPLY FIRBERGLASS RESIN OVER EPOXY. IT WILL POP OFF! Of course you need to scuff it up first and be extremely careful using MEKP. That stuff will knock your d!(k in the dirt! It is strong! Wear gloves and a respirator. An inexpenive carbon filter one will work as long as you have decent ventilation. Scuff between coats and shoot two or three, let fully cure, and polish. We did many carbon fiber and graphite parts this way in the Air Force. Once you spary a coaedt, remove the paint cup, cover it with plastic and place it in the refrigerator to impeade the curing. Clean the gun thouroughly. When getting ready for the next coat, let the cup of epoxy come to room temperature with the cover in place. A touch of MEKP may be needed again. If it is too thick to spary, discard it and mix up a fresh batch. We had heat lamps to speed up the curing which took about 90 minutes per coat. Got beautiful results. Of course, experiment on some metal pieces or something else first to get the hang of spraying epoxy.
Rick
Loranger, La
1980 Stepside LUV (Again)
