It is currently Sun Apr 05, 2026 2:08 pm
 Post subject: lowering front end,
PostPosted: Tue Mar 03, 2009 10:52 pm
i know to losen the bolts on the underside of the framerails but do i need to jack it up first??? if anyone could lend a bit of advice i lowered my truck a long time ago and the guy i sold it to raised it back up so now that im in posetion of it again it needs to go back down!!!! this time for good!!!!
thanks,
daffernm
 Post subject: Re: lowering front end,
PostPosted: Wed Mar 04, 2009 2:17 am
It would make it easier to turn the bolts by jacking it up. Takes the load off and less chance of stripping one.
PostPosted: Wed Mar 04, 2009 8:35 am
Moved! :roll:
PostPosted: Fri Mar 06, 2009 9:53 pm
Also remember to count how many times you turned the bolt one one side, that way when you go to do the other side you know how many times to turn it to keep everything level.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Tue Apr 07, 2009 8:05 pm
depending on how low you want to go you will need to remove the bump stops
PostPosted: Mon Apr 13, 2009 6:39 pm
How does that affect the front end alignment and camber?
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Mon Apr 13, 2009 7:54 pm
It changes the camber and you need to have it realigned.
PostPosted: Tue Apr 14, 2009 5:41 pm
Ahh, thought so. Just checking as my brain cell has been on the blink lately. Precurser to senility I guess!!
Rick
Loranger, La
