It is currently Mon May 25, 2026 12:34 pm
 Post subject: floor pans
PostPosted: Fri Feb 20, 2009 3:07 pm
any body know where i might be able to get so or so out of onther that might fit kinda close
 Post subject: Re: floor pans
PostPosted: Sat Feb 21, 2009 6:43 pm
PITA Old Fart
Some people have just welded in sheet metal to patch them. I wire wheeled mine to clean off the rust and fiberglassed them on both sides - then primered, painted, and undercoated them.
PostPosted: Sat Feb 21, 2009 7:34 pm
fiberglass isnt realy an option for me
PostPosted: Sun Feb 22, 2009 9:14 am
From the looks of the pic it looks like you need to pay some attention to the body mount.
PostPosted: Sun Feb 22, 2009 10:42 am
my 79 is/was almost as bad as yours. I cut out all the rust, bent some sheet metal to lay in place overlapping by about two inches and for the time being it's bolted in place. I will weld it in eventually. I would definitely do something with the body mount. Mine only had some surface rust on it so I gave it some love and it's fine.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sun Feb 22, 2009 3:23 pm
im just going to build a new body mount but as far as rust gose the floor pan is the only bad place that is rusted so im glad about that evyery where else is just serface rust
PostPosted: Mon Feb 23, 2009 3:08 am
Make a replacement panel with a 1" overlap. Get the tool that puts a indented edge on the panel. (Harbor Freight). Cut the overlap down. You do not want a large area which water can get between the panels. When you are welding to the body mount, loosen or remove the bolt and cushion, support the cab while you weld.
PostPosted: Mon Feb 23, 2009 9:56 am
well kinda cold right now and i havent had a chance to work on the truck in a couple of days but, iv been debateing on weather or not to take off the cab.
PostPosted: Thu Feb 26, 2009 10:24 pm
going to cut floor pans out of an olds thats just sitin in my back yard dad cut it up for a parts car for the dirt track car then gave what was left to me for scrap so it might be a little easyer to make floor pans out of floor pans..
PostPosted: Mon Apr 06, 2009 9:39 pm
you can do what i am going to do for my 79 4x4 is just cut some good ones out of a junk yard truck and then weld them in and reforce the body mount section since it seems like they all rust right there
