It is currently Tue Jun 30, 2026 9:07 am
 Post subject: Wiring on turn signals
PostPosted: Sat Mar 29, 2008 9:57 am
Got a problem. I'm putting in new LED type turn signal lights on the front bumper. I can't seam to get them wired properly. I went to change the flasher and the ones they are trying to sell me don't look right. They are a 2 prong with prongs like this _ l , mine in the truck has a 3 prong plug and the flasher is a 3 prong flasher like this l _ l . What make it even more wierd is the plug only has 2 wires coming out and they are these l l .
Does anyone have any insight on what flasher I should get?
PostPosted: Sat Mar 29, 2008 10:20 am
i have lleds on mine and didnt have to change the flasher, mine blink like the originals not fast like they say it (may) and if so change to led flasher...
but if need be http://cgi.ebay.com/ebaymotors/3-Pin-El ... enameZWDVW
PostPosted: Sat Mar 29, 2008 11:07 am
cat, do you have the part number for the original flasher and is it suppose to be a 3 prong. I see the one on the Ebay is a 3 prong.
Thanks,
PostPosted: Sat Mar 29, 2008 12:06 pm
i dont have the number or now if its original but ill check in a bit
PostPosted: Sat Mar 29, 2008 3:47 pm
That's OK, I was able to get mine off and it still works with the original lights, somehow the LED lights just won't work. There has to be something different about the wiring, I think I need a ground some where because I can ground the hot wire going into the light and the flasher works but the light don't since it is grounded before going through the light. Without the ground the flasher won't even blink.
PostPosted: Sat Mar 29, 2008 4:00 pm
There should be a hot wire for the park light, a hot wire for the turn signal, and a third for the ground on the LED, I believe...
PostPosted: Sat Mar 29, 2008 5:39 pm
Thanks mytmouz, that's right the new light also has 3 wires. The guy at the parts store said the white on the LED is the ground and if I'm correct the black on the pickup is the ground. There's not too many ways to change up the rest. I was able to get the running lights to work on either wire on the LED but the signal won't work on either. I thought I was smarter than a dumb light but now I'm not to sure. :smt017
PostPosted: Sat Mar 29, 2008 6:25 pm
I did check mine and the flasher has 3 prongs but the luv wire only has to (l l) the _ was no wire in it even thought its the 3 prong plug and flasher... mi light are the led type that go into the original socket a didn’t have to wire them in.... I didn’t like them so i run normal bulbs now but I did keep the led tail lights... dont know if that helps
PostPosted: Sat Mar 29, 2008 8:13 pm
Yeah, thanks for the help. I guess I am smarter than a dumb light because I had them wired correctly the first time. It was the battery that was smarter than me. Apparently the battery had just enough charge to allow the hazard flashers to work but not the turn signals. I tried to start her up and she wouldn't go so I jumped it. Low and behold the signals started to work. I just hope I haven't caused something to short. Hopefully this one has a happy ending. :lol:
PostPosted: Sat Mar 29, 2008 8:33 pm
well that would do it, happened to me once trying to figure the thing out (don’t remember now) found out battery was almost dead , glade it all worked out… pop us a pic if you get a chance
PostPosted: Sun Mar 30, 2008 8:37 am
All I have left is figuring out how to finish it (chrome, powder coat or paint). Most likely paint because of the economics. I have another string "Fab new bumper" that I will post pics on.
btw, your truck is awsome.
Thanks for the assist.
