It is currently Wed Jul 01, 2026 7:32 am
 Post subject: Chassis Measurements?
PostPosted: Sat Feb 02, 2008 1:51 am
G'day, I've been a member for quite a while but I haven't posted much.
I was wondering if someone could take some measurements of their luv for me as I currently don't have one to measure (I had a '76 but I crushed it, I'm picking up a '73 in the next couple of weeks).
I would like to know track width of the front end from the mounting surfaces and the distance between chassis rails (outside or inside measurement).
Any help would be much appreciated.
Gilly
PostPosted: Sun Feb 03, 2008 8:08 pm
I hope this helps you. I took it a year ago off my 76'
PostPosted: Sun Feb 03, 2008 8:20 pm
I know the front end rail width is just perfect for a jaguar series II front end to be welded in place :wink:
Bob
PostPosted: Sun Feb 03, 2008 8:33 pm
Australian LUV Guru
I hope you salvaged all the good parts off it, spares are hard to come by in the land of OZ.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Feb 04, 2008 12:50 am
thats exactly what i was after. thank you very much.
Quote:
I know the front end rail width is just perfect for a jaguar series II front end to be welded in place Wink
jag hey? could be an option. i was going with something else but that could be cheaper...
between the rust and the bloke that owned it before me, there was nothing left to lose... im the guy thats after the tub you have or are getting soon.
PostPosted: Mon Feb 04, 2008 9:37 am
Are you down under???
I would just buy an 88 or newer and put the cab on that.
Do some measurements on the Jag thing. Width wise it looks to work really well. Not sure on how the ride height would be.
My mate whos doing it is out of action, had an op last week, had 4 tendons re attached in his shoulder and something about a rotator cuff or something. He will be out for a while.
But then its not getting a luv or pup cab on it either.
Cheers, Bob.
PostPosted: Tue Feb 05, 2008 1:56 am
Yeah i come from the land down under...
In NSW for a few more weeks then Im moving back to WA.
Im a little bit addicted to fabrication, so as soon as i have made up my mind on a few things and as soon as i have a shed again i will be cutting everything off the chassis and starting again. whether i use jag components on the front end or not depends on the 'look' i end up going for, I want the front end to look as neat and simple as possible.
thanks for the info, very handy. want body is going onto your friends luv chassis? is he putting a rod on it or something?
PostPosted: Tue Feb 05, 2008 8:18 am
Yeah hes got a 42 chev truck cab he is doing for a friend of ours. And a 48 F1 ford for himself. The Jag gear was for the ford, the chev allready had a dodgy HQ setup on the original chassis in it that needs to be redone some how. He got another propper std chev chassis and he is not sure if he wants to box it out and K frame it etc using the old butchered chassis or if he just starts with a pre boxed rodeo one.
I dont think you can get much more neat and simple than torsion bars.
With the Jag you would have to go coil overs. Ive seen them in rods but with a custom made crossmember to simplify the look. A-arms is neater than the strut bar in the luv/rodeo.
Bob.
PostPosted: Fri Feb 08, 2008 8:13 pm
Hey guys I'm still after a wheeltrack measurement if anyone can help me out. need distance between mounting surfaces on the front.
Thanks
Matt
PostPosted: Wed Feb 13, 2008 2:48 am
1355mm if my memory is right.
Thats the front track, not sure if its mounting face of centre of tread to centre of tread.
Bob.
PostPosted: Wed Feb 13, 2008 4:45 pm
Cheers Bob, much appreciated!
