It is currently Tue May 26, 2026 12:04 am
 Post subject: layin it flat.
PostPosted: Mon Jan 07, 2008 11:06 pm
Okay so my 82 luv is now in peices undergoing a makeover. the question I have is how do I pull off a clean body drop. I cut the rockers clean off so they don't hang lower than the bed (looks way better) and I know the stock floor body drop will leave me with even less space in the cab which defeats the whole purpose of the extended cab desighn I have been putting together. So what exactly is a traditional body drop and how do I go about it. I would like the body to sit about 1/2 inch higher than the bottom of the frame. But with the rockers gone I got a long ways to go. Any suggestions?
PostPosted: Tue Jan 08, 2008 5:28 am
you got pics of your truck there is a whole list of stuff that can be done and different to get the job done right and there are a few people on here that have done the drop the frame will need to be zd and after you get pics then we get a better idea of what will need to be done so you got it bagged and what motor you got pics first so we can got a good idea to start i did a body drop on a suburban and a few other rides but not a luv yet but the guys here will help out a lot ok :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Tue Jan 08, 2008 12:31 pm
You have the b/d's mixed up, stock floor is the way to go. New frame from the firewall back. Traditional is when you cut the floor and let it drop and build up the floor.
PostPosted: Thu Jan 10, 2008 8:23 am
Correct. Alot of work and a little bit of space is what you get when you b/d a Luv
PostPosted: Sun Jan 13, 2008 4:12 pm
So what if I were to cut about 2 inches out of the frame section under the cab and weld braces inside. Then do about a 2 inch traditional body drop? would this work without giving up too much cab space?
PostPosted: Mon Jan 14, 2008 1:41 pm
can you get pics of your truck and tell us about it like bags or hydros wheels/tires motor a list of what your truck is this will help alot
dangerous-toys4life
75 k-5 2x
94 king cab
