It is currently Thu Jun 25, 2026 2:54 am
 Post subject: Bags on an 82
PostPosted: Fri Dec 07, 2007 9:46 pm
I've wanted bags on my luv for a long time now and I'm ready to do it. But I can't see a good way to mount a bag between the upper and lower control arms on my 82 luv. It looks like the shock mount is in a terrible place as far as bags are concerned. Is there anyone who managed to bag their 81-83 luv with stock suspension up front? If so is there any place I could go to see some pictures of how to go about it? I can see how easy it would be to go hydro with this set-up but I would much rather go bags if at all possible. If you can help in any way please let me know. Thanks.
Joey
PostPosted: Sat Dec 08, 2007 4:35 am
http://forums.luvtruck.com/viewtopic.php?t=13796&postdays=0&postorder=asc&start=40
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Dec 08, 2007 7:38 am
Make sure that you look at what type of bag you want to run, PSI and the diameter of the bag. I think dan used one of the bigger double bellow bags you can get. They have bags ranging from 6" to 8 1/2" diameter. If you look at smaller bags like a 2500 or a 2600 LBS bag than the size will be smaller from brand to brand. I had 2600 LBS Firestone bags on the front and rear of my 86' burban with a 454 and never had any problems with it. I had a Airride technologys kit on my blown 86' mustang that also had Firestone bags and again no problems. The only thing I can say is do your reseach and see what everyone is doing for airride. Everyone has a different way of doing things and you might find one way that will work for you.
Craig
