It is currently Thu Jun 25, 2026 5:45 am
PostPosted: Mon Nov 26, 2007 2:41 pm
i was wondering if anyone has ran i high rise manifold with out changing to a cowl hood. if you have send some pics please. im stuck on this any help would be great
PostPosted: Mon Nov 26, 2007 5:11 pm
your avatar is HUGE
PostPosted: Mon Nov 26, 2007 5:36 pm
I run an edelbrock rpm airgap with cheater plate system & demon 650 with stock hood .
PostPosted: Mon Nov 26, 2007 9:47 pm
Depends on what you call a highrise manifold. Normal ones should. I have a edelbrock too, but I have a small late model Camaro scoop just for grins. :)
PostPosted: Tue Nov 27, 2007 8:36 am
Thats also going to depend on how high your motor sit in the truck and how tall of an air cleaner you want to run. I have a super victor, NOS plate, and 4'' air cleaner with a 4'' scoop and need every bit of it.
PostPosted: Wed Nov 28, 2007 1:40 pm
i'm running a hurricane high rise with a edelbrock carb and i'm also going to run dual cold air intakes to the carb. i was just wondering if you guys had to cut and move then re weld the hood or not?
PostPosted: Wed Nov 28, 2007 4:02 pm
Cipherex wrote:
your avatar is HUGE
you need to resize your avatar please :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Wed Nov 28, 2007 5:28 pm
PITA Old Fart
For info about resizing your avatar check this out:
http://forums.luvtruck.com/viewtopic.php?t=7593
