It is currently Mon May 25, 2026 10:53 pm
 Post subject: Rear Window R and R
PostPosted: Sat Feb 24, 2007 5:58 pm
Is it possible/feasable to remove a rear window and get the rubber out in tact. I have a sliding window in my other truck Id like to put in the 80 and im not sure on the availablility of the rear window rubber. Or does anyone know where one can obtain rear window rubber?
PostPosted: Sat Feb 24, 2007 6:11 pm
It can be done, but you have to be careful, and go slow.
1980 LUV Mikado 4X4
2003 Chevy S10
PostPosted: Sat Feb 24, 2007 11:09 pm
At this time, you cannot buy a "new " rear window seal. Only used ones, so be very careful .
PostPosted: Sun Feb 25, 2007 8:53 am
i found a place called steelerubber. saw them on car crazy on speed channel. there website says they offer front and rear rubber, with or without trimlock. no door seals though. the guy on tv says they can make any seal you want with a good sample. and of corse enough $$$$$.
PostPosted: Mon Feb 26, 2007 1:29 am
Now do I just push on the window and pop it out or is there a special trick. If I was just replacing the rubber I would just cut the lip and pull out the window. Do I need to lube it to help it out? Anyone tried this before?
PostPosted: Mon Feb 26, 2007 1:42 am
i alwayes used my hand on the inside top corner and pressed ... from the out side used a screwdriver to go between the rubber and cab , push- pry once it starts to come out just work your way around from the inside and have some one on the out side to hold or catch the glass.... did this 4 or 5 times a year when i had my canopy with reach threw ( no window ) in cab
PostPosted: Wed Feb 28, 2007 7:52 pm
My son has a new rubber and slider in his 80. I took it out with ease when painted it. Just start at top on one side and work your way around. Might be a different gasket than an original.
I have some friends that work at a auto glass company I can check with/
PostPosted: Sat Mar 03, 2007 1:07 am
It looks like JC Whitney has a complete body-seal kit that includes fron, side and rear glass seals.
No idea how it fits, though.
Edit: Nevermind - it's a Blazer kit. :(
1978 shortbed fleetside, th350, Fireball 231 Even Fire V6, Edelbrock 500CFM Performer with Edelbrock intake. Workin' Truck.
PostPosted: Sun Mar 04, 2007 6:50 pm
Thanks for the effort anyway, good thing though it was a little rich for my blood.............
Users browsing this forum: Google [Bot] and 25 guests
