It is currently Mon May 25, 2026 7:38 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3
PostPosted: Sun Mar 22, 2009 12:05 pm
I am running 5 bolt all around 5-4.75 rear 5-4.5 front 9" Ford rear end and the Toyota rotor conversion up front.
PostPosted: Sun Mar 22, 2009 12:12 pm
Due to i am not that good on moving web addresses here is a site for disc brake conversions including a bolt on disc brake bracket for the s-10.
Scarebird Classic Brakes llc
PostPosted: Tue Mar 24, 2009 1:06 am
Disk brakes do not lock up as quickly as drums, due to the fact that drum brakes are referred to as self actuating.
PostPosted: Tue Mar 24, 2009 5:05 am
Thansk all for the great responses
PostPosted: Tue Mar 24, 2009 3:07 pm
so which master cylinder will work without the booster in other words no power brakes.
PostPosted: Tue Mar 24, 2009 4:11 pm
mytmouz wrote:
napa number 39178, The Carquest number I have is: BPR20-1860. Right around $25 with a core charge.
These are PN's for a Chrysler minivan master that is an aluminum body. The Strange and Willwood styles are copies of this. Most racers I know end up switching to these from the big names as they get more pedal pressure...
I am running the Napa one...
PostPosted: Tue Mar 24, 2009 7:35 pm
Aerospace also has the same Chrysler master cylinder. It is proportioned front/back so you don't need a proportioning valve. That is what I have on my drag truck.
PostPosted: Tue Mar 24, 2009 9:23 pm
I have question for you guys that are running the master cylinder napa number 39178 how is the brake peddle pressure feel.
I am running the aerospace front disk brakes and ford explorer disk on the rear with a 1 1/8" corvette master cylinder it stops OK but the peddle is really stiff.
I would like to make the peddle softer with out going to a booster.
PostPosted: Tue Mar 24, 2009 9:35 pm
Mine need to be bled again before I can tell, seem fine for now...
PostPosted: Wed Mar 25, 2009 1:36 pm
I have a 80s-90s Jeep Cherokee aluminum master on mine works good for me also have a new Nisson disc/disc master that i am going to put on later (7/8" piston i think)
PostPosted: Sun May 30, 2010 7:41 pm
I'm in the middle of installing a v8 in my 80 luv and I have a toyota straight axle under my front and just bought new caliphers for the toyota stuff and was wanting to change out the stock MC and do away with the booster because my engine want have much vacuum ( I'm building a mudd racer and will not have rear brakes) so will the NAPA 39178 work for just the front brakes? Or should I just run the stock mc and don't hook up the booster.
PostPosted: Sat Oct 09, 2010 11:55 am
What I did for weight in the bed was went and got a 16 gal fuel cell and mounted it between the fender wells to the back added just enough weight when full plus added a rear bumper that i can inject water into it hold ruff of 18 gals and i mixed it with antifreeze so it wouldn't rust so I hook up nice with the v8 running 400hp
LIVE HARD PLAY HARDER
PostPosted: Mon Oct 11, 2010 6:55 pm
If your running a v8 just use a power steering pump and run hydroboost. :D
Users browsing this forum: Google [Bot] and 22 guests
