It is currently Mon May 25, 2026 3:32 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 78 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Aug 30, 2010 3:34 pm
i understand that is fine.just wondered if there was any progress
PostPosted: Mon Aug 30, 2010 4:03 pm
Hey Dr. I see you're from the city of the lost causes also. How is your disc brake conversion going? I'm really enterested in this swap. Which luv do you have? Do you drive it around lost cause?
PostPosted: Tue Aug 31, 2010 9:02 am
zyanug wrote:
i will apologize for dr_frankenstien, he works at a place that constantly sends nhim away for weeks at a time. i know he will get back to you guys as soon as he gets close to a computer
Thanks Boss, I got caught out at work again.... and summit has been slow about shipping parts!
A.j.
PostPosted: Tue Aug 31, 2010 9:07 am
I have 3: 76 micky, 79 2wd, 80 4x4. I dont drive my trucks around town, not yet atleast... once I have the new turbo motor going in the 79 im going after that blown S10 with the big block. that ass is mine.
the conversion works great, and Steve up at M&S Auto says its easy to align.
which truck are you? lemme guess........ the orange one with the small block swap? or that super clean blue one with the headache rack?
A.j.
PostPosted: Tue Aug 31, 2010 11:54 am
Unfortunately none. I have a faided blue 80 luv. It used to be in top shape until the young brother inlaw drove it for a while. That blue one going up 70 all the time is a nice truck. Haven't seen the orange one. When your suspension up grade is complete I would like to see it if that's ok. I'm gonna have to start fixing up the luv mobile pretty soon. Was kinda thinking about a 300hp v6 but not sure yet.
T
PostPosted: Wed Sep 01, 2010 8:00 am
T
come on by, you can see it for yourself!
A.j.
PostPosted: Fri Sep 03, 2010 2:45 pm
OK MORE PICTURES!
OK, This are your Lower Ball Joint Adapters. They are professionally machined and come either bare or with pre pressed BJ. Pretty obvious how they bolt in.
OK, This is your upper Coil Over Adapter. They are professionally machined and bent. Made of low carbon cold roll steel for maximum strength to material ratio. EASY BOLT IN, NO WELDING NEEDED and will EASILY SUPPORT BIG BLOCK WHEEL HOPS.
Here is an Internal Shot of how the assembly works and looks. During Early MockUp stages here.
A.j.
PostPosted: Fri Sep 03, 2010 3:08 pm
THE KIT CONTENTS
Here we are going over an UPGRADE KIT> Listed for 499. THIS IS A STAGE 2 KIT.
Heres all thats INCLUDED:
1:INSTRUCTIONS
2:UPPER COILOVER SHOCK ADAPTER
3:UPPER BALL JOINT
4:REPLACEMENT BUMPSTOPS
5:DISC BRAKE DUST SHIELDS
6:OUTER TIE ROD END
7:INNER TIE ROD END
8:TIE ROD SLEEVE
9:PREMIUM BRAKE PADS
10:S10 SPINDLE
11:LOWER BJ ADAPTER
12:ALL GRADE 8 HARDWARE
13:A/N -4 BRAIDED SRAKE LIKE 90*
14:SPEED BLEEDER FOR GM METRIC CALIPER
15:A/N -4 ADAPTER TO JAP-10mm-1
16:CRUSH WASHER /SEAL BRAKE LINE
17:DUST CAP
18:SPINDLE NUT AND WASHER
19:LOWER BJ
20:INNER/OUTER ROTOR SEALS
21:HUB BEARINGS. OVERSIZE TO USE BUICK GNX BEARINGS.
22:ROTOR - DRILL/SLOT. OVERSIZE RACES TO USE GNX BEARINGS
23:NHRA LEGAL 1/2" STUDS AND MAG WHEEL LUGS
THIS IS EVERYTHING NEEDED LESS ACTUAL COILOVERS TO CONVERT FROM THE STOCK LUV 6 LUG TO A GM METRIC SPINDLE AND 5 LUG ROTOR.
I understand that everybody would like a list made for them, but time is a little short for me and the volume of kit request has kinda loaded me down. This may take time to get your kit delivered. Everything is hand machined. as of currently........ wait time is 1 month for a kit. I have torn my suppliers up on GM Metric parts! Every other kit made uses same spindle assembly, so theres adapter kits for 4 models now. Monza/Vega bodys, LUV trucks, D50/RAM trucks, Fiero/chevette... so parts back ordered.
A.j.
PostPosted: Fri Sep 03, 2010 6:44 pm
Nice. If I still had my V8 LUV, I'd gladly swap this in.
PostPosted: Sat Sep 04, 2010 12:26 am
hi. so are you actually able to use this without the coilovers? i would want to still use my stock suspension.
PostPosted: Sun Sep 05, 2010 2:19 pm
What's the difference in that kit and the standard 299 kit?
PostPosted: Tue Sep 07, 2010 8:26 am
thats correct can be used with either coilovers or stock suspension.
A.j.
PostPosted: Tue Sep 07, 2010 8:42 am
exactly what you said, Standard.
No drilled and slot rotors, no braided brake lines or the adapters, standard grade 5 hardware. the brackets are made with cheaper materials, brake pads are std quality, calipers/spindle/dustshield are all reclaimed OE equipment, etc etc.... this is what makes the 299 kit possible.
while the stage 2 kit is entirely brand new. and is designed with the race car in mind.
The Idea behind this kit is your buying my time and homework. I thought that was fair for a long future of engineered replacement parts on the LUV.
I designed the kit and what it requires to be easily made and maintained, for 299 - you get everything you need for swapping better brakes and 5 lugs to your luv. very little thought needed... comes with everything you need and the instuctions give part numbers and direction for all other items. The Idea is ease of the kit.
If you need to do it under the stricktest budget, I sell just the brackets and the instuctions to duplicate the kit using your own sourced parts. for the ebay warrior.... it could be cheaper than what the kit sells for....
A.j.
PostPosted: Thu Sep 09, 2010 11:28 am
What is the stock bolt pattern on a 79 LUV? 6 x 5.5in. or 6 x 135mm?
PostPosted: Thu Sep 16, 2010 2:54 pm
I have no idea.... the stock 6 lug is terrible.
A.j.
PostPosted: Fri Sep 24, 2010 4:53 pm
How exactly do you contact this guy to buy something?
PostPosted: Sat Sep 25, 2010 6:20 am
CLick the pm icon in any of his posts, and go from there...He will get back with you eventually. Remember, this is a side deal so he may not be online everyday...
PostPosted: Sat Sep 25, 2010 10:16 pm
The stock pattern is 6 x 5.5
PostPosted: Tue Sep 28, 2010 2:05 pm
yes I apologize! if you need something please PM me.
I would give out my tele phone number but last time I did I got spam like crazy...
here is my email if you would like to contact me directly.
drfrankenstein56@yahoo.com
A.j.
PostPosted: Sun Oct 24, 2010 8:52 pm
I would like to see if you can give me some individual prices on the coilovers, your mounts,and then the lower ball joint adapter..thanks ....we have all the s10 stuff already thats why im asking..thanks again
