It is currently Mon May 25, 2026 5:25 pm
PostPosted: Mon May 22, 2006 11:44 am
Has any one figured out any new ways to convert the front wheels to a 5 lug bolt pattern yet? I cant find anyone in my area to redrill my hubs. I really dont want to buy an aerospace kit either.
PostPosted: Tue May 23, 2006 8:32 pm
i looked into this. The vega conversion seem to work good. There is a toyota conversion, but it requires alot of machine work. I gave up and bought 6 bolt fronts and 5 lug rears.
PostPosted: Tue May 23, 2006 8:50 pm
Thats me too, and you don't even know the diffrence unless you look real close, plus you for sure cant tell, when the wheels are turning :D
PostPosted: Tue May 23, 2006 9:20 pm
i bought gm corvette style rally wheels from summit racing so lugs are covered with center cap. the only time the caps won't be on is at the track.
PostPosted: Wed May 24, 2006 9:42 am
Hey Hotrod did you get the the 6 lug truck wheels for the front and the 5 lugs for the back? I was thinking about doing that but I couldnt tell in the pictures that summit shows if the wheels are the same minus the bolt pattern. The other reason I was seriously considering changing the front to 5 lug is the Rear end I have that I am thinking about using is pretty wide but Weld wheels has a wheel with a funky offset that will allow it to work but the catch is they dont make the same wheel in a 6 lug for the front that will match.
PostPosted: Wed May 24, 2006 9:44 am
OOPS I forgot to ask where I can find more info on the vega conversion?
PostPosted: Wed May 24, 2006 5:31 pm
Yea thats what I did the manufacture is wheel vintiques. I had to call them direct and get the part #'s and then call summit to order by part #. Summits price was cheaper the the manufacturers retail price. Go figure. Anyway the offer the rear in up to 5" back space and will make anything you want. My back wheels are dual pattern, both ford and chevy, they call these the hotrod line. The front are what they call a pre-71' truck rallye wheel both take the same cap. I don't have tires mounted or the centers in yet but I'll put picks up soon.
PostPosted: Wed May 24, 2006 6:03 pm
cool I was looking earlier today on summits web page and didnt see the ford pattern So thats cool I will have to check into that if that is the route I end up taking.
PostPosted: Mon Jun 12, 2006 3:03 am
I HAVE A GUY IN WASHINGTON WHO WILL REDRILL AND FIT THE CHANGE OVER BEARINGS SO THE ONLY THING YOU HAVE TO DO IS RERADIUS THE CALIPER TO FIT AROUND THE ROTOR
HE HAS A FULL SERVICE MACHINE SHOP AND HAS DONE QUIT NICE WORK FOR ME IN THE PAST
IF YOU WANT I WILL SEND YOU HIS EMAIL ADDRESS AND PHONE NUMBERS
STOCK VEGA ROTORS IS WHAT I DID MY CONVERSION WITH
 Post subject: 5 lug rotors
PostPosted: Tue Jun 13, 2006 6:43 am
:idea: I used Toyota rotors of a 94 p/up all i had to do was have my machine shop build spacer rings then we heated them installed them on the spindles then bolted the rotors on. I needed to use 1 head bolt washer off a 2.2 Chysler engine( thats what i had that worked at the time) 1 for each bolt and i was driving in no time. They ar a ford bolt pattern to.Of course i drilled mine for d-gassing and to lighten them even more. :wink:
PostPosted: Tue Jun 13, 2006 5:49 pm
I have a set of these rotors with all the bearings, washers, nut and dust caps if anyone is interested. I paid $80 for the set.
Users browsing this forum: Google [Bot] and 27 guests
