It is currently Mon May 25, 2026 6:08 am
 Post subject: patching bad body spots
PostPosted: Mon Mar 08, 2004 11:17 pm
ok i can tell you all its taking a lot of time to do this one piece on my 55 ford f 100 on the bottom of rear fender grrr i come very close so far on this one piece and so far taken a good couple hours not over lapping just flush all i have to work with i have come up with is a vise and a sheet metal brake and body hammer kit oh and welder no cool english wheel any experienced auto body guys in here got some ideas that you could share would appreciate it cause i got a lot of parts to patch :)
PostPosted: Tue Mar 09, 2004 2:31 am
A 55 probably doesn't have a truly straight line anywhere on it. It just takes a lot of time. Better tools will trade for some of that time, but not all of it. For overly curved stuff a sandbag and rounded hammer come in real handy. That lets you put that curve in the metal going both directions. You might be able to rig something like that with a round nose hammer and something with a little give to pound on. I've done some just messing around type stuff pounding on a block of wood, or just some good clean dirt.
In the end, if you have to miss it fitting exactly, make it an indentation that you can skin over with filler. Starting out and not having a full on body shop, sometimes you have to smooth things with a little bondo. Just don't fall back on it too quick and do as much as you can to cut down the amount needed.
PostPosted: Tue Mar 09, 2004 11:51 am
I found luck by duct taping a wire mesh behind it, then putying it. Then after that taking a thing that looks like you will gouge someone's eyes out and getting all of the really extra putty off (Bondo), then doing a rough sand then doing another bondo, then repeating the process then getting an orbital sander and sanding it down then priming both the back and the front. But I always nail the back with the navy rust goo first.
PostPosted: Fri Mar 12, 2004 9:52 pm
Well people are helping me out in town with tips like using a wet rag
after welding a little bit. I should have thought of that. I also got the
piece shaped the right way. Might use the body hammer a lil bit but i
guess i will figure it out.
If you guys could share some tips that'd be cool. The other night i was
totally mad cause i thought i wasnt doing the process right but my dad
said it didnt look bad that made me glad i ll post some pics soon of how
its goin.
James
ps i am trying to work on grammar so you can read it
PostPosted: Sun Mar 14, 2004 12:35 am
go ahead and laugh at my pics :lol: this is my first time patching anything on a car body
here is some pics of the truck and parts almost down to whole frame
i like the way the past owner had the exhaust kinda cool
here is the other parts that need body work :o :lol:
dont worry i still love the luvs just got the project of this goin
hope you enjoy the pics get a good laugh
James
