It is currently Mon May 25, 2026 8:20 am
 Post subject: not sure?
PostPosted: Mon Jan 25, 2010 11:37 am
This is probably here some where but I can't locate it. My torsion bars are stuck and will not come out. I have removed everything I think and they won't come out. Any insight would be greatly appreciated.
"You know you gotta LUV me"
 Post subject: Re: not sure?
PostPosted: Mon Jan 25, 2010 6:51 pm
did you take the nut off the front of the lower a-arm? if so just give it a tap from the front... it work on mine...
PostPosted: Tue Jan 26, 2010 2:51 pm
PB blaster after doing what ctmandu said above, All tension must be removed from the bar!! BFH, BIG punch and access to the end of the bar, from the front IIRC..... If you are going to coil overs, I think you said.... Heat it with a torch, only if you do not want to use them again. BFH, BIG punch and access to the end of the bar, from the front IIRC. You could cut them but I do not think that will do any thing for you. Front end may need to be off the ground.
I only adjusted mine on my luvs, but replaced them on my Dodge Dart that had Torsion bar front end.
PostPosted: Tue Jan 26, 2010 2:52 pm
If you are going to coilovers, just cut them off at the lower a arm, they won't fall out...
PostPosted: Tue Jan 26, 2010 6:13 pm
I just want them out I am bagging the truck so I could care less unless someone wants to buy them!!
PostPosted: Tue Jan 26, 2010 6:39 pm
I know this may sound crazy, but you DO have the truck on jack stands with the suspension relaxed? Right?
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Tue Jan 26, 2010 7:05 pm
Of course I do! I know what you mean though theres some people that really dont know what they are doing.
PostPosted: Tue Jan 26, 2010 11:06 pm
Then it is sawsall time. They are tempered steel, so I do not know if a sawsall will cut them... Fire up the old torch.
PostPosted: Wed Jan 27, 2010 10:01 am
Small (4"-4 1/2") cut off wheel and a peanut grinder.
PostPosted: Wed Jan 27, 2010 12:17 pm
I have removed many torsion bars and they ALL came out easily using a small mallet and piece of round steel for a punch. Yes I admit the first one I did the truck was on jackstands, but they were under the suspension and wouldn't move. Interesting!
Rick
Loranger, La
PostPosted: Thu Jan 28, 2010 2:02 am
and some lube wd- 40 will help it get out
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Thu Jan 28, 2010 1:48 pm
Well one of them are out now but now the other side is giving me porblems. The upper ball joint wont break free from the spindle. I dont think I can spray more lube, or hit the pickle fork any harder!! If its not one thing its another. This is my frustation coming out
PostPosted: Thu Jan 28, 2010 3:20 pm
Keep the faith bro
PostPosted: Sat Jan 30, 2010 1:35 pm
Success finally hahaha. Now next question I am bagging it and the ball joints bind up after they articulate so much what can I do to change this to get lower with out changing to 5 lug?
PostPosted: Sat Jan 30, 2010 3:25 pm
pie cut the upper a-arm to help it then weld it back up
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sun Jan 31, 2010 9:36 am
Now I have found 2 different ways that pie cutting has been explained. One way on here and another somewhere else. Can someone help me?
PostPosted: Wed Feb 03, 2010 11:32 am
No one??
PostPosted: Mon Feb 22, 2010 5:50 pm
Cat,
We removed the front nut. The back torsion bar adjusting nut's threads stripped out as we backed it out. Do we need to cut this bolt to remove the torsion bar?
mr.T
PostPosted: Sun Feb 28, 2010 4:30 am
hello,
Would anyone be willing to sell me their old front suspension? Many of you have converted to coil-over and I was wondering if you still had the torsion bars, adjusting arms/bolts laying around--that you have no more use for. The original front suspension works really well for us. As Mr. T previously mentioned, we have unfortunately stripped the driver-side adjuster bolt and adjuster arm and would be interested in a spare set(both sides) since we cannot find these parts for sale anywhere. Also, any ideas as to how to get these torsion bars out if you are not able to extract the adjuster bolt due to extreme strippage?
thanks in advance for any help or advice,
phil
