It is currently Mon May 25, 2026 10:01 am
PostPosted: Sun May 11, 2008 4:09 pm
im thinking about putting leafsprings or 4link coilover on a 4wd luv. i want to use as much luv parts as i can. i hope to get that done this summer and maybee next summer put a small v8 in the luv. leaf springs would probably be easier than 4link and cheaper but i would like to keep it as my daily driver any ideas?
PostPosted: Sun May 11, 2008 6:37 pm
find the front and rear axles from a early 80's toyota,get the leaf springs too.easiest and cheapest way to go.
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Sun May 11, 2008 6:52 pm
how hard will the toyota springs be to make fit the luv frame. are the springs too wide for the luv frame or will they match pretty well
PostPosted: Sun May 11, 2008 10:33 pm
four links are very difficult/expensive to set up correctly. I have at least $3500 tied into the 4-links/coilovers on this pig
First time around you would be better off starting with toyota axles like all ready stated. I would use toyota rear springs in the front and 63"long chevy springs in the rear. Obviously you are going to have to make all your own mounts but it should be pretty straight forward
PostPosted: Sun May 11, 2008 11:53 pm
ive looked up coil overs and they are spendy! my other question is steering. will i have to have power steering to turn 33s i know it will help a crap load but for a while do u think it will kill me :D and why rear toyota springs in front and chevy springs in rear?
PostPosted: Mon May 12, 2008 6:58 am
longer = higher. (and more stable but softer)
Bob.
PostPosted: Tue May 13, 2008 9:58 am
its not to tough to turn the 33s without power steering man it would be nice though
No luv right now =(
PostPosted: Tue May 13, 2008 3:28 pm
Watch out for that dog!!!! He is going to mark your tires and wheels. :)
PostPosted: Tue May 13, 2008 8:28 pm
You could probably get away without power steering. The yota/chevy combo gives you a few inches of lift, are commonly available, and flexy 8) . Plus the yota springs have an offset center pin to move the front axle forward which moves your tires away from the firewall
Nah, fortunately she's not a tire marker, she's just just likes to check everything out :egeek
