It is currently Tue May 26, 2026 12:24 am
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: LUV dually
PostPosted: Thu Sep 27, 2007 11:01 am
Hey,
I found this post when searching for dual wheels for my 1980, just wondering where this project is at?. Its a pretty old post so hopefully this has been completed.
I'm looking to do a dual wheel conversion on mine as well as make a flat bed dump, if anyone has helpful info please let me know.
Right now my focus is on the dual wheel part. I guess I could do the adapters but it would be nice to beef up the whole rear end. My final goal is to add a v6 or a diesel of comparable size. Its an automatic and I will have to check the trans #, I completely rebuilt it about 3 years ago so its good and strong. I'm not looking at making it a super truck just able to make it work for me. As it stands stock, I have had a almost a half ton of material in the bed and it hauls fine I added helper springs and it made a difference but I need it to be able to haul at least a pallet of brick or block around town and I think dual wheels and some suspension tweaking will achieve this.
Comments welcome
Thanks,
J.P
PostPosted: Sun Oct 14, 2007 12:10 pm
Probably should also put up in here what im doing as well as the other thread you started about your fuel issues.
86 4x4 space cab.
It was a bit dark and i took em with the camera in my phone.
The track match is A1 so it should handle like a bought one. Only worry ive got is the chassis join. Its not an easy thing to get approved down here. That and the lack of park/emergency brakes at the wheels. And if i dont lengthen the wheel base im going to have no room for a fuel tank.
Was going to be for the 2x4 but for $300 i couldnt go past buying the 4x4. Im going to use 2.6L running gear. I would actually like ti use a later post 88 chassis, for the bigger front diff and brakes. Will see if i can find one.
Its a work truck, i was going to V8 or V6 the 2X4, i would do it to the 4x4 but the trans and transfer case would send me broke.
Picked up the diff wheels springs and that bit of the chassis for $275. Its the same ratio as a 1 ton Isuzu and its out of a little Isuzu truck with the 14" rear wheels.
Bob.
 Post subject: Luv dually
PostPosted: Fri Oct 26, 2007 11:43 am
I have a set of 6 wheels & tires [dually rear] off a '78 luv I'll sell.
Users browsing this forum: Baidu [Spider] and 24 guests
