It is currently Mon Jun 29, 2026 5:35 pm
 Post subject: My small block
PostPosted: Mon Apr 03, 2006 12:30 pm
Ok im 17 and i just got my luv almost on the road, but i have came to the decision that im swapin motors first... Tho i am 17, I am very car literate, but i just have a cuple luv specific questions.... I have a 400+ HP 283, and im puttin a TH350 with a 3000 stall behind it... Now my motor is built about as good as you can get without a supercharger, but this means it has to breathe.... i have a huge cam in her, and i want to know about headers... I have a set of block huggers, but some say that even block huggers dont work... I have a high torque mini starter so that frees up space on the passenger side, where the exhaust will be piped... Also i am having all custom exhaust done on it so i just need to know if the block huggers will work, and if you guys think this will still give me enough breathing... o and by the way i am having dual 2.5in exhaust all the way back... so just give me some input
~jams
PostPosted: Mon Apr 03, 2006 9:17 pm
Japanese Redneck
block huggers will work fine for 400hp. its not the best but it will do. I dynoed one of my old motors at 575hp on 1 5/8" hooker regular 1 5/8" comp headers but I'd say 450+ is about the mark where you want to get into big tube, equal length headers. If I were you i would spend the extra $$$ and get some Sanderson 1 3/4" primary block huggers. better yet just get the hooker V8 LUV conversion super comps they are 1 3/4 or 1 7/8 LT headers.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
PostPosted: Mon Apr 03, 2006 10:16 pm
I agree with LUVSADRAG, grab some of the conversion headers and let that bitch breathe! 8) Full Length Tube Size 1.75" x 34", Collector Size 3", Collector Length 10".
PostPosted: Wed Apr 05, 2006 9:19 pm
I have a set of 1 5/8" block huggers on my 383, motor made 490hp with 1 3/4" full length dyno headers, I'm guessin its loosing around 10-20hp, and 30-40tq with the huggers, full length will make way more in the mid range. Also for a 283 I'd go 1 5/8" full length if you can get some.
74 Luv - 383, 224/224cam, 200-4R, Dana 44 w/373s,
smooth idle "work truck" - 11.30 @ 121.8
67 camaro - 502 street/strip (inthe10s)
PostPosted: Thu Apr 06, 2006 3:34 pm
green luv machine there is a set on ebay right now.
74luv383 good to hear from you. I met you at hrp the other day.
PostPosted: Thu Apr 06, 2006 11:26 pm
Hotrod
Was it the day when all of Texas showed up?
And I made that one pathetic pass...
Well went back 2 weeks ago, when we had the cool weather and made some low 11 sec passes with good mph, Luv ran better then I expected, but so did everyone elses car with the awsome air :D
Hope to see your Luv out there one day.
Rafel
PostPosted: Fri Apr 07, 2006 5:42 am
Yea that was the day. I'm getting closer motor is at the balancer.
