It is currently Mon Jun 29, 2026 11:24 pm
PostPosted: Mon Jan 30, 2006 11:46 pm
Luvtruck.com Wookie
i'm gettin ready to get the exhaust in the 2.8 truck, and have suffered a quandry.
i planned on doing a true dual w/ 1 3/4" pipe.
where do i put the o2 sensor? does it even matter?
since it's a tbi engine every cyl get the same mixture right?
TiLtEd wrote:
Boobies!!! :D
PostPosted: Tue Jan 31, 2006 7:21 am
Swap Specialist Mod
id just put the o2 on the pipe that comes right off the manifold. drill a hole, weld in a bung and off you go.
PostPosted: Tue Jan 31, 2006 3:12 pm
If you don't have much room you can mount it down stream a little farther and use a 3 wire heated sensor. The sensor must be able to get to 500 degrees f before it startes to respond to the oxygen changes in the exhaust. The closer to the manifold the better on a 1 wire sensor.
PostPosted: Wed Feb 01, 2006 10:17 am
Luvtruck.com Wookie
my concern is more along the lines of sticking it in a true dual exhaust, if the puter gets an acurate reading if it's only exposed to one cyl bank's exhaust
TiLtEd wrote:
Boobies!!! :D
PostPosted: Wed Feb 01, 2006 8:46 pm
You just need to expose it to one bank so the ecm will get a reading and calculate off the amount of oxygen its seeing and compinsate the air fuel mixture either rich or lean.
