It is currently Tue Jun 30, 2026 4:27 pm
 Post subject: 2.8 engines
PostPosted: Thu Jan 19, 2006 8:39 am
does anyone know if there is a difference in the blocks for a 1983 carb 2.8 engine and a 1986 2.8 f.i. engine? witth the blocks interchange? thanks
pat(slotracer) :?:
PostPosted: Thu Jan 19, 2006 11:36 am
I believe the 2.8L was the same carb or efi up to mid to late '87 when they switched from external to internal balancing for the crankshaft... that helped reduce the crankshaft breakage problem of the earlier motors...
PostPosted: Thu Jan 19, 2006 1:25 pm
i've got a H.E.I for it if your interested.
