It is currently Mon May 25, 2026 11:30 am
 Post subject: 9 inch
PostPosted: Thu Mar 10, 2005 4:57 pm
does anybody know where/what kinda of care 9inch differntial comes from. i keep on hearing that this one is the best one for a v8 swap, but i do not know where to begin. I don't know if it is special order or if i can pick it up from a used car or what . ... please help . . . thanks!
PostPosted: Thu Mar 10, 2005 6:42 pm
i know the easiest way to find em is to look under the older F-100s and 150s. Its realy easy to tell if its a 9" or an 8.8" (the 8.8 has a removeable diff cover).
PostPosted: Thu Mar 10, 2005 7:48 pm
As far as getting a used 9" I think you would be better off to get one already narrowed. By the time you get one narrowed, and shortened/ or new axles, you might as well get one from ebay or buy an aftermarket.
I got lucky, there was one in my maroon truck when I got it....
Resident lurker
PostPosted: Fri Mar 11, 2005 11:14 pm
I got to go with diarmadhim. It will be a longshot finding a rear end that will suit your application. Going for an aftermarket might be the better way to go. I got great deal on a used, narrowed 9" assy for my truck that was in pieces. After getting drums, axle bearings with seals, brake kits and shoes, smaller relocated perches and a 3rd member rebuild, the cost was just over 1000.00. What sold me on taking on the project was the fact that it had 2.75 to 1 gears. Unless you have an inside line on getting a rear end rebuit and narrowed with a gear ratio that you are looking for, It would be better to get one made brand new from the ground up.
PostPosted: Sat Mar 12, 2005 1:21 am
i assume that your doing a v8 swap. what kind of power is this thing going to be putting out. if its like anything under 350 you can just get an s10 rearend and put that under it. the s10 rearend is a direct fit in the luv.
just my .02
neil
PostPosted: Mon Mar 21, 2005 1:20 pm
With the 9 inch rearend installed will the tires/wheels stick out any
1980 Chevrolet LUV stock 1.8L longbed
1980 Chevrolet LUV parts truck shortbed
1983 Suzuki Gs550 Sportsman
1989 Nissan King cab P/u <totalled> 4/1/06
1986 Full size Chevy P/U
1993 Volvo 850 GTL
PostPosted: Mon Mar 21, 2005 4:30 pm
Not if you setup the width to what it needs to be.
If your asking if you can install at stock 9 inch then I would say no. LUV's are pretty narrow compared to vehicles that came with 9 inches. The wheels would stick out a bunch. Anyone have a hard figure?
PostPosted: Mon Mar 21, 2005 8:30 pm
If I remember right the narrowest stock 9 was like 57". about 4" wider. So technically if you got one you could bolt it up and run it... you'd just need really skinny wheels 8)
Resident lurker
PostPosted: Mon Mar 21, 2005 8:48 pm
Here's some info i got from the Internet...
Width: from wheel mounting flangeto wheel mounting flange (X)
· 1957-59 Ford - 57 1/4" · 60-64 Ford 61 1/4" · 57-59 Ranchero and SW - 57 1/4" · 1964-71 Full sized cars - 61" · 1979-81 Lincoln Versailles - 58 1/2" · 1972-79 Ford intermediate & Full Size - 63" · 70-79 Ranchero/Torino - 63" · 57-72 F-100 Pickup - 61 1/4" · 73-86 F-150 Pickup/78-86 Bronco - 65-65 1/4" · 66-77 Bronco - 58" · 1977-86 Ford E-150 - 69 1/4" · 77-81 Granada/Versailles - 58 1/2" · 67-70 Mustang/Cougar/Fairlane/Comet/Falcon - 59 1/4"* · 70-73 Mustang family - 61 1/4"* · 69-77 Galaxie/Lincoln - information not given but in any case it will need to be narrowed for use in a street rod.
Width: from housing flangeto housing flange (Y)
· 57-59 Ford/Edsel - 52" · 60-64 Ford/Mercury - 54-56" · · · · · 70-79 Ranchero/Torino - 56" · 57-72 F-100 pickup - 57" · 73-86 F-150 pickup/78-86 Bronco - 58 3/4" · 66-77 Bronco - 46" · · · 67-70 Mustang/Cougar/Fairlane/Comet/Falcon - 52-54" · 70-73 Mustang family - 54" · · 58-60 Thunderbird - 50" · 65-66 Mustang - 52" · 66-69 Cyclone - 52" · 61-67 Thunderbird - 56"
PostPosted: Wed Mar 23, 2005 10:15 pm
I got a 9" set up on ladder bars with dutchman axles ready to go fits right in 15*10 hang out about 1" . Spooled and ready to rock
PostPosted: Thu Mar 31, 2005 11:56 am
could always get a toyota 8" from a 4x4 -- 6 lug to match your luv, all kinds of gear and posi options available and beefy axle shafts. should take 350hp in a street setting with an upgraded carrier(like a detroit truetrac).
it was also found under some 2wd toyota trucks with a 5 on 4.5 lug pattern
