It is currently Mon May 25, 2026 2:53 am
 Post subject: Wireing Harness ?'s
PostPosted: Fri Nov 19, 2004 2:20 pm
I think im going to need a complete new wiring kit for my truck. The people that had it before me thought they knew what they were doing but obviously had no clue :? . So now im thinking that i need to re-wire the entire truck but have no idea were to find a kit that would work. Can any one help with this?
PostPosted: Fri Nov 19, 2004 3:18 pm
You could go with a painless kit http://www.painlesswiring.com/ (also available at places like Eastwood, Jegs, etc) They are pricey though if you are just fixing up a stock truck. I've gone through a couple of trucks that had been rewired by some real idiots, and usually they don't manage to cut things too far back, you could just unwrap the harness and start hooking things back up the way they are supposed to be. Start with one side of the engine bay, then move to the other side, following the diagrams (in the info section of luvtruck.com) all the way. Its not easy, but in many ways its easier than yanking everything out and starting over again. A new harness will get you better wiring in the end, but its no evening project.
PostPosted: Fri Nov 19, 2004 8:59 pm
I haven't installed it yet but I bought a harness from ez wiring. Went with it cause it was quite a bit less expensive than the Painless one. they're on ebay or visit...http://www.ezwiring.com
Resident lurker
PostPosted: Fri Nov 19, 2004 9:05 pm
Or.....(and PLEASE, don't anybody think I am "pushing" my parts) I am merely throwing this out there because maybe he can't afford a NEW harness......
I have several good, complete USED wiring harnesses, and when I say complete, I mean not ONE wire has been cut 8O
It's just another option for him, and I am having a big blow-out sale right now :D 8)
PostPosted: Fri Nov 19, 2004 9:09 pm
True, true + I know I had a hard time (mentally)forking over the $$ for mine 8)
Resident lurker
PostPosted: Fri Nov 19, 2004 11:57 pm
If its in that good of shape, there is no way I would buy new. Wouldn't see the need, my .02 :D
 Post subject: $165 Wiring Harness
PostPosted: Mon Nov 22, 2004 6:07 pm
I know I may be late but check out this sight, http://www.clpart.com (435) 229-5381 This were I got my wiring harness from for $165. It's a 21 circuit, pre wired fuse panel harness.
PostPosted: Mon Nov 22, 2004 6:29 pm
ummm that looks an awful lot like a computer animation site, not a place to buy wiring harnesses...
Resident lurker
 Post subject: try this again
PostPosted: Mon Nov 22, 2004 6:45 pm
Thanks man! Let me know if this works. If not, this is the name is C and L's Street Rod Wiring Harness
http://www.clparts.com/aprodpages/awiring.html
PostPosted: Mon Nov 22, 2004 6:57 pm
That worked. The harnesses there are the same as the one I got. I went the ebay route. ended up being $160 including shipping. Most however are $165 + shp, for this harness. There is also another brand out there don't know how good it is or isn't. It's called "It's a Snap" they have them on ebay too...
Resident lurker
PostPosted: Mon Nov 22, 2004 10:55 pm
like i said. the wireing in my truck is all wacked out so i need something that will work for every day driving. If you could PLEASE send me some more info on what you have......
PostPosted: Tue Nov 23, 2004 10:39 pm
PM sent w more info as requested 8)
PostPosted: Wed Nov 24, 2004 9:35 pm
I just LUV when i go out of myway to send all the info i possibly can.....to jus never recieve a reply :roll:
PostPosted: Thu Nov 25, 2004 3:26 pm
sorry, I'm kinda new at this. Were can i find the info?
PostPosted: Thu Nov 25, 2004 3:40 pm
