It is currently Fri Jul 03, 2026 8:08 am
 Post subject: just got a 1980
PostPosted: Thu Jul 22, 2004 4:49 am
hi i have had plenty of car this is my fisrt truck and converstion. i got a 1980 luv short wheel base, it has a pos rear end and has had a sb in it i'm buying a rolling chassie trying to find the parts that i need such as headers,trans stick, a radiator option,tire and wheel set up. if anyone willing to help i would greatly appre. any help. o can the inter finder be remove?
thanks
otha
PostPosted: Thu Jul 22, 2004 11:45 am
Welcome to the site.
The inner can be removed with some TLC. I took mine off the other day with a minimal amount of strong arming it.
PostPosted: Thu Jul 22, 2004 12:36 pm
Block hugger (1 5/8") headers work real well, fit good and good access to everything,
also Hooker makes a set of 1 3/4" long tubes.
Radiator sizes are around 22"x19", I have a Griffin, but try the Summit brand, good quality.
Lokar makes a flexable dipstick for the trans, gotta have that with a V8 Luv.
I have a set of 15"x10"s in the back with M/T 26"x10.5", they rub the inside of the bed on
tight turns. I measured the rear fender space - its 12", so an 11" tire will fit.
74 Luv - 383, 224/224cam, 200-4R, Dana 44 w/373s,
smooth idle "work truck" - 11.30 @ 121.8
67 camaro - 502 street/strip (inthe10s)
