It is currently Wed Jul 01, 2026 9:22 am
 Post subject: Tranny
PostPosted: Tue Apr 13, 2004 11:33 pm
My boss has got a tranny the came out of a 3/4 chevy that was behind a 454 he's putting in his chevelle. If I get a divorced t-case, how big and hard is this tranny gonna be to install and can I hook up his buick 305 to the front :?: Thanks.
1980 Luv Mikado 4X4
PostPosted: Wed Apr 14, 2004 9:53 am
I doubt the buick will bolt right up to the tranny. I'm guessing the bolt pattern won't match. for instance the th350, has diff, patterns for diff brands from GM, ie buick th350 wont line up on a chevy and chevy won't line up to a buick.
Resident lurker
PostPosted: Wed Apr 14, 2004 9:55 am
Maybe I can talk him out of the turbo 350 he's got on the 305 now.
1980 Luv Mikado 4X4
PostPosted: Wed Apr 14, 2004 1:18 pm
If the 'Buick' engine is a 305 Chevy it will fit but more than likely it will be the 305 Olds and that will not fit a Chevy tranny. Go id the 305.
Good luck
Fitzworld
A driveway full of Full size American 4x4 iron and one
LUV Diesel long bed
PostPosted: Thu Apr 29, 2004 3:12 am
Here's 2 questions for all you super knowledgables. 1-Will the torque conv. from a t-400 fit in a t-350??? 2- I noticed that the rear shaft [ where the drive line slides on ] on the 400 was bigger then the t-350. Did the 400 come out of something like a 3/4 ton truck? Thanks T.
PostPosted: Thu Apr 29, 2004 8:48 am
I think the 400 converter will work on the 350 but I could be wrong, wouldn't be the first time. The 400 is a beefier tranny thoughout because it was initially built for use in trucks. G.M. also used them in a number of their bigger cars.
PostPosted: Wed May 05, 2004 4:31 am
I want to sell a turbo 400, and was just curious what you guys think I should try to get for it. I have seen them in the paper anywhere from $350 down. It came out of a truck that blew the motor, so the trani should still be good. I think.
