It is currently Thu Jul 02, 2026 10:32 pm
 Post subject: why change rear end?
PostPosted: Sun Feb 15, 2004 7:16 am
other than the 6 lug pattern why change the rear end? especially for a weak s10 rear- what can the advantage of that be?
PostPosted: Sun Feb 15, 2004 8:45 am
OG Lifer
If you are going to an scb, then the luv rear end won't hold up to the stock horse power of even a 350,
for long :wink:
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Sun Feb 15, 2004 11:44 am
i couldn't see the advantages of an S10 rear either. those things often grenade if you look at them wrong :lol:
PostPosted: Sun Feb 15, 2004 2:20 pm
Gear ratios are a big thing to consider as well. I chose the jeep wagoneer dana 44 because I could keep my 6 hole pattern, bigger brakes, and a good veriaty of gear ratios.
PostPosted: Mon Feb 16, 2004 6:17 am
what gears might be in the rear end? it is a 75 with a manual tranny. are these rear ends as tough as the s10?
thanks for all you help it is appreciated
PostPosted: Mon Feb 16, 2004 6:27 am
My other luv had a jeep amc20 rear and that thing was bullet proof. Well til the ol'lady hit 1st gear doin about 90mph and well im sure you know the rest of the story.
PostPosted: Mon Feb 16, 2004 9:26 am
moose, manual should be 4.56. Automatics have 4.10.
Resident lurker
PostPosted: Mon Feb 16, 2004 4:26 pm
sounds like somebody was smoking somethng when they decided to put a higher ratio in an auto...can you say SLOW???
and to my knowlege, the lowest you can gear an s10 rear down would be 4.10. dana 44s can go to either 5.38, and toyota axles go all the way down to 5.71(5.29 is a better choice, since 5.71s are quite weak)
 Post subject: posi
PostPosted: Tue Feb 17, 2004 6:41 am
any chance it might be posi?
PostPosted: Tue Feb 17, 2004 9:36 am
Actually, the higher the numbers, the lower the top end speed. Unless you are doing a lot of off-road driving, or drag racing with a good final gear ratio trans, you should stay away rear end gears in the 5's. For a daily driver, especially one that might see highway miles, I would recommend getting down into the 3's. You won't be reving the engine as high and you will get better fuel mileage.
