It is currently Sun May 10, 2026 2:36 pm
 Post subject: double valve springs?
PostPosted: Sat Feb 11, 2012 11:25 am
Ok Oz Gemini guys are telling me double springs are available for the g series engines. Anybody have a part numbers or engines I should be looking at?
PostPosted: Sat Feb 11, 2012 3:01 pm
Australian LUV Guru
Here in Australia the G200 heads are factory fitted with double valve springs. :ebiggrin
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Feb 11, 2012 9:51 pm
What years are they hydraulic lifters? Isky makes a cam for the 1.9.
PostPosted: Sun Feb 19, 2012 11:53 pm
please do not get all excited about using metric terms.
I assume you mean the G200Z and its probably easier for all if you etch that into your brain and use that term.
Its a SOHC motor and as far as i am aware there isnt one in existance that uses hydraulic lifters.
Tappets or bucket and shim.
The factory double springs were not use for some hotted up racer motor. Just a stocker. If you want a hotted up racer motor i would suggest you look to one of the aftermarket manufacturers for a spring (or springs) that would be suitable.
