It is currently Fri Jul 03, 2026 1:02 pm
PostPosted: Wed Apr 13, 2011 7:38 am
I've already done a search on the topic and have not seen a specific parts list required to change out a points distributor in my stock 80 4x4 Luv to an electronic ignition. I do not want a Pertronix unit, I want the real deal. I'd prefer to use stock style componants (as opposed to MSD, etc) in order to keep costs down. So, I understand I need am 82- up electronic distributor, what other componants do I need to complete the setup and where do I find them?
Thanks!
PostPosted: Wed Apr 13, 2011 9:52 am
That is all you need.... 83-87 pup distributor is direct bolt in and one ground wire and one hot wire then crank, start, and drive away. It is super easy.
PostPosted: Wed Apr 13, 2011 8:06 pm
What he said is very true and you will notice a difference as soon as you start it.
One more thing adjust the plug gap to the wider specs of the later engines for optimum results.
PostPosted: Wed Apr 13, 2011 8:15 pm
I've got one electronic conversion and we just put in a pertronix setup in my sons LUV. Take your pick and go with it. It's one of the best upgrades you can do.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
