It is currently Sun Jul 05, 2026 1:04 am
 Post subject: straight 6 swap
PostPosted: Thu Feb 03, 2011 12:03 pm
hey everyone just bought a luv and i have an engine swap ?
my buddy owns a 84 supra and he is doing a 7m swap on it and he said i can have his 5m well considering luv has around 2.5 hp i thought it would be a fun swap to do but i was just curious on how much of a pain its goin to be and if anyone has done this swap or even a 7m swap cause the 5m and 7m are damn near the same engine any info is greatly apretiated
 Post subject: Re: straight 6 swap
PostPosted: Fri Feb 04, 2011 3:02 pm
likely you will need to go to a electric fan for more space.
other than that, i hope you have a 2WD truck?
before you start riping and taring do some tape measuring, and see if it will clear the fire wall to RAD and hood to frame space.
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Fri Feb 04, 2011 4:29 pm
It will be a tight fit, you most likely need to cut the firewall. Its like putting 10 lbs of shitin a 2 lbs sack. Like its been said a million times here, just small block it.
PostPosted: Fri Feb 04, 2011 4:48 pm
i agree with luvrv8
the v8 is much easier. BUT i was thinking about the exact same swap X^D you WILL have to modify your firewall to put in that straight 6 but once it was done it would be an epicly fast little truck. and since a luv is actually lighter than a supra it would make an incredible sleeper.
PostPosted: Mon Feb 07, 2011 9:06 pm
yeah i finaly got it to my house and was lookin at the space i dont think i wana go that route ima just put it in a celica i think ima do a ka24 swap
PostPosted: Fri Feb 11, 2011 9:39 pm
hey man if its worth the thought ive heard of people making the 5m swap in a first get toy and they dont got much room either so i got to say go for the 5m swap if it dont go in, it dont go in.plus i would be cool to see it!!
PostPosted: Sat Feb 12, 2011 8:53 am
I say what's the worst that could happen jus use a hammer an a torch till it fits
PostPosted: Tue Feb 15, 2011 12:19 am
hell go buy some sheet metal and cut the fire wall and re make one that will fit around the engine
Users browsing this forum: Bing [Bot] and 31 guests
