It is currently Mon May 25, 2026 1:32 pm
 Post subject: Muncie 4 speed question
PostPosted: Thu Jul 15, 2010 11:25 am
I have a chance at buying a used muncie 4 spd. I already have a SBC with a TH-350 installed in my 79' LUV. Would the 4 Spd fit with the same transmission mount as the TH-350?
PostPosted: Thu Jul 15, 2010 11:36 am
It should...
PostPosted: Fri Jul 16, 2010 7:49 am
Might have to move the cross member,I don't think the trannies are the same length and it might take a different mount.
PostPosted: Fri Jul 16, 2010 8:16 am
I am planning on cutting out the transmission cross-member because I have removed the torsion bars any way and I need more room for the exhaust.
PostPosted: Fri Jul 16, 2010 10:02 am
I have swapped a muncie in place of a powerglide lot's of times on my 67 Chevelles, same mount and tranny x member location. 'glide and 350 are usually the same, of course, there is always the oddball...
PostPosted: Fri Jul 16, 2010 10:13 am
With my luck I always get the oddball one that requires a BFH to make it fit, :smt021, but thanks for all the replies.
PostPosted: Sat Jul 17, 2010 2:50 pm
The Muncie should be a bolt in replacement even down to the drive shaft and yoke .
PostPosted: Mon Jul 19, 2010 6:43 am
That makes me feel better
PostPosted: Tue Jul 20, 2010 11:09 am
PostPosted: Tue Jul 20, 2010 11:42 am
Thanks PapaG!
