It is currently Sun Jul 05, 2026 4:28 pm
 Post subject: v8 pedal question
PostPosted: Thu Oct 22, 2009 6:18 pm
im doing a v8 swap and bags all at the same time so all the little stuff ive over-looked.
do i have to use a whole new pedal assembly or can i utilize the stock brake and gas pedal? ill just remove the clutch pedal
i searched and didnt find this, im sure i read right over it if it were there, sorry if i did
 Post subject: Re: v8 pedal question
PostPosted: Thu Oct 22, 2009 7:08 pm
I just removed my clutch pedal and adapted the V-6 throttle cable to work with my stock gas pedal
PostPosted: Thu Oct 22, 2009 8:23 pm
i know ive seen in summit and such related catalogs actual pedal assemblies. can i go with one? or does the stock pedals hold up well enough if installed properly
PostPosted: Thu Oct 22, 2009 8:58 pm
I am using the stock pedals...
PostPosted: Thu Oct 22, 2009 9:37 pm
ok. good to know
PostPosted: Thu Oct 22, 2009 11:33 pm
Stock pedals with a stock chevy cable. Cable part number was 336961.
PostPosted: Fri Oct 23, 2009 1:45 am
I used the $12 spectre universal cable . Had all the adaptors for almost every type of set up and very adjustable .
PostPosted: Fri Oct 23, 2009 3:55 pm
I also use the stock pedals...and I use a Lokar cable...
PostPosted: Sun Dec 06, 2009 6:30 pm
What I used was like a 70's c-10 throttle cable, a stock manifold cable mount and my original throttle pedal arm but welded the c-10 bracket to the top..it looks like nothing was ever messed with.
PostPosted: Sun Dec 06, 2009 10:27 pm
What he said X2
PostPosted: Mon Dec 07, 2009 6:12 pm
The auto transmission version has a wider pedal, but most of us just use the one that is already in the truck.
PostPosted: Fri Jan 21, 2011 12:52 am
I have stock petals as well and when broke my throttle cable I bought the wrong one everything worked fin just the plastic end ap came off while racing so I had no throttle thankfully I had speaker wire I wrapped it around the car. And ran it through the firewall just to get home that was a fun trip back so point is just make sure you get the right cable
A careful driver is one who honks his horn when he goes through a red light. -Henry Morgan
PostPosted: Fri Jan 21, 2011 12:55 am
Did you notice that you responded to a thread from 2009? I am sure its figured out by now.
