It is currently Mon Jun 29, 2026 12:30 pm
PostPosted: Sun Jan 24, 2010 5:26 pm
any recommedations on a specific engine? should i swap out the transmission? basically what all do i need to get a 350 in there?
Perception is 9/10 of the flaw
PostPosted: Sun Jan 24, 2010 6:38 pm
Try the search section should point you in the right direction many have done and are doing the same swap.
PostPosted: Sun Jan 24, 2010 8:57 pm
Er, check the info section on the luvtruck.com main page, there's a write up about the small block swap. You'll be going 350/TH350 auto, the stock trans is out in a 350 SBC swap.
