It is currently Fri Jun 26, 2026 9:05 am
 Post subject: hooker motor mounts
PostPosted: Sat Apr 05, 2008 11:12 am
HI ya'll. I was looking on the jegs web site at hooker motor mounts for luvs(kit 520-12606) and the pic look different than the ones in the info section on here. The ones i found look like the bolt in but i'm not sure how. Could the pic be wrong?
 Post subject: Re: hooker motor mounts
PostPosted: Sat Apr 05, 2008 7:37 pm
The hookers bolt in and then you have them welded to the frame for strenght. They set on the frame and have a notch on them were they mount.
PostPosted: Tue Apr 15, 2008 8:11 am
yes they have changed the mount,i just looked them up and it's not the same. i wonder how these mount up?
PostPosted: Tue Apr 15, 2008 8:22 am
after some looking into jegs has the wrong picture with the part number, go to summit and look at p/n HOK-12606HKR that is the same mount. looks like jegs need to fix the picture.
PostPosted: Tue Apr 15, 2008 9:47 am
That's what I was thinking. Not sure what Jegs has up but sure looked funny
PostPosted: Wed Apr 16, 2008 10:48 am
Thanks , the pic made it look like they would bolt in-not that lucky
PostPosted: Wed Apr 16, 2008 1:08 pm
Oh you could bolt it on I suppose if you drill though the frame from the side.. Don't think you could get both from the side and top. Youi might use a large self tapping from the top along with a all the way through side bolt.
I would recommend welding it though.
