It is currently Tue May 26, 2026 6:00 am
 Post subject: Isuzu vs S-10 rear ends?
PostPosted: Thu Feb 14, 2008 7:58 pm
I'm going to swap a 4.3L and T700 into my '75 Luv. All over there is the recommendation to use the S-10 rear end. I understand why. It fits. It's easy. It's Chevy. The problem is having to ship drums or disks off to have them converted to 5 lug. Troopers come with V6 motors and nice highway gearing for fuel mileage. AND, they have the Luv 6 lug pattern. Is there any reason to avoid trooper or Pup rear ends? Why not do this and save some money and time? Thoughts on this. vs
PostPosted: Thu Feb 14, 2008 10:19 pm
What year s10 rear you plan on usin? I used an 89 and had to get the hubs/axles re-drilled to 6 lug to match factory luv bolt pattern
PostPosted: Fri Feb 15, 2008 5:01 pm
Nothing wrong with Isuzu rears.
PostPosted: Fri Feb 15, 2008 6:14 pm
PITA Old Fart
I'm running an '86 Pup rearend and I've had no problems. It's a lot tougher and stronger than my old stock Luv rearend, plus the gear ratio is way better. I put mine in at the same time I installed a 5 speed from the same donor truck, and it made a huge difference in power and gas mileage.
PostPosted: Fri Feb 15, 2008 7:28 pm
I was wondering... Is there a source for different ratio differentials online for the Isuzu rearends? I have a 79 4x4, if I upped the ratio in each differential it would be a gas saver, on top of the 5th gear-but I do like the ultra low rock crawl ratio in it now!
PostPosted: Thu Feb 21, 2008 7:37 pm
Hey taz, what ratio do you have on your rearend, 3.73 or 3.42?
Hold on to your lug nuts, it's time for an Overhaul!!!!!!!!!
PostPosted: Thu Feb 21, 2008 8:45 pm
Well, the plans have changed a little. I just found an 87 P'up in my neighborhood. The lady wants 500 for it. It's got a good motor, 5 speed and rearend. Only thing it doesn't have is a title. That's cool. I'll make a trailer of the bed and cut up and scrap the cab. Since I have a '75, I'll have to modify my motor mounts a little. After 76 Isuzu moved the block mounts about 4" aft. Not a problem, just a small weld job. When I yank the 2.3L it's going to the shop for a rebuild with my tax return check. In about a month I should be running a fresh-painted, 0 miles, classic, gas-saving, original-looking Luv. I'm taking pictures and will put them up. Thanks for all the help.
Khy in Austin, TX
