It is currently Tue May 26, 2026 12:04 am
 Post subject: buick 231 ?
PostPosted: Wed Nov 14, 2007 10:53 pm
ok I am picking up a 79 231 Saturday and plan on using a downey off road bell housing with a Toyota 5 spd , offy or elderbrock intake with twin side draft weber carbs (adaptor to 4 barrel intake) with mild cam so here are my question
1. What gearing would be good for at least 100/120 top speed and what rear end can I find it in
2. How do I make the speedometer work with the luv gauges?
3. What headers work with the luv?
4. If I use cable clutch bell housing can I use the luv cable or do I need to fab something
PostPosted: Wed Nov 14, 2007 11:02 pm
gears would depend on a few things,how many rpm,s you want to turn,and how much overdrive 5th gear has. Example=.825 5th gear with 3.50 rear gears turning 215/50-15's around 5000 rpm would be around 120mph
72 luv v-8 owned since 16!
240" rear engine dragster
[color=#FF8000]
29 dodge 4 dr sedan (project)
PostPosted: Wed Nov 14, 2007 11:39 pm
i dont know what the toyota 5spd is but the tires i would like to run will be 245/50/14.. trans would be a 1985-newer Toyota 5 speed and with cam i think it said 5000/6000rpm ... buick is low rpm i am told and with the cam i can get about another 1000rpms... this is all new to me
PostPosted: Thu Nov 15, 2007 12:58 am
found this , any one here know buicks? i think this would work... i was told v8 and v6 used same bell housing, can anyone conferm this for me
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 59741&rd=1
PostPosted: Thu Nov 15, 2007 1:25 am
For a Speedometer, One interesting thing we have been doing with our waterski boats up here for a speedometer is using a hand held GPS mounted to the dash. Might be able to find the right unit and make a custom mount for it. Take advantage of a little technology. instead of figuring out how to calibrate the speedo. Just not going to work to good when you are running those logging roads at 120mph in your luv......
Current Fleet
pics
PostPosted: Thu Nov 15, 2007 6:29 am
Yep,the buick v-6 has the same bellhousing bolt pattern as the BOP v-8s. :)
PostPosted: Thu Nov 15, 2007 9:28 pm
If you run the 245/50-15 with the stock luv 4.56 @ 6000rpm it would run 112mph If you used a 4.10 ratio it would run 114mph @ 5500rpm Hope this helps
[color=#FF8000]
PostPosted: Sat Nov 17, 2007 10:45 pm
Not to hi-jack the thread but I have a questoin about upgradin to a turbo on a 231. Is it a direct bolt on (turbo, manifold, etc) to the stock 231 or would I need to upgrade anything else? Thanks!
PostPosted: Sun Nov 18, 2007 12:43 am
in my searches i found this take a look http://www.beforeblack.net/conversion.htm oh and you got the turbo intake i sent you right
PostPosted: Sun Nov 18, 2007 12:56 am
Yes I did ctmandu, I actually found that on ebay before you sent me the link, I just kept forgettin to ask my question on the site! Thanks for the link though!
PostPosted: Sun Nov 18, 2007 2:17 am
You could use a 3.42 ratio out of a diesel luv and keep the rearend and lug pattern the same.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sun Nov 18, 2007 10:06 am
I already have an s10 rear end redrilled to 6, but that is a good idea!
PostPosted: Sun Nov 18, 2007 11:29 am
i like that idea... didn't know that i thought they where all the same
PostPosted: Sun Nov 18, 2007 5:07 pm
Did you pick up the engine then? Is this an upgrade for your current truck, or are you building another one?
PostPosted: Sun Nov 18, 2007 6:18 pm
didnt get time to get it so ill try friday if they are open... yes it wil be for my curent truck, my 79 sst luv
