It is currently Mon Jun 29, 2026 6:12 pm
 Post subject: 9 inch deal
PostPosted: Thu May 24, 2007 4:14 am
ok i got a guy that will supply a 9" big bearing housing,cut to my dimension and weld on ends for 100 plus 35.00 shipping. what is the widest i can go on width of the rear end to get a deeper 5 inch backspacing and a shallow dish 2 too 3 inch with a 15x8 rim without it hanging out. stock is 53 axle flange to axle flange and what stud pattern is the best to use 5x4 1/2 or 5x4 3/4 ?
PostPosted: Thu May 24, 2007 5:39 am
Your best bet on the rear end width is to get the wheels you are going to use, set them in place, and get the measurement you need. As far as the lug pattern, the 4 & 3/4 is more common, but if you are going to convert the front to 5 lugs, I'd make them the same. The Toyota conversion would be 4 & 1/2. It's also slightly easier to redrill to 4 & 1/2 if you can find someone to do it. I believe the aerospace kit will come with either, your choice, but I could be wrong.
PostPosted: Thu May 24, 2007 5:52 am
thanks terry,
this deal is looking pretty good so far the housing cut and welded ,strange st axles,retainers,bearings, and stud kit is right at 510 plus shipping.
PostPosted: Thu May 24, 2007 5:55 am
Very sweet, the sticker shock will come in when you decide you want a Nodular center section...
PostPosted: Thu May 24, 2007 5:58 am
yes i have already looked at that shock. 8O
