It is currently Mon Jun 29, 2026 8:59 pm
 Post subject: SPOOL
PostPosted: Wed May 16, 2007 9:07 pm
Can I run a rear end with a mini spool on the street without alot of problem ?
PostPosted: Wed May 16, 2007 10:02 pm
You can, but it can be a pain. I had a spool in a 67 ss Chevelle, I had the skinny front tires, about 5,000 miles a set. New outer tie rods about 12,000 miles or so.
PostPosted: Thu May 17, 2007 6:35 am
Yes you can i run a mini spool in my truck, but you have to be careful cornering as tight turns will eat up the tires and always make sure you don't punch it while cornering as it will get ugly instantly.Just use some common sense and you can have fun.
PostPosted: Thu May 17, 2007 9:43 am
I have mini spool in mine also like TJ said watch tight corners especially on pavement. I run MT sportman pros so they give a little bit in corning. My main gripe is taking a long curve at highway speeds it starts pushing like fat bitch in a buffet line. :D
PostPosted: Thu May 17, 2007 9:44 am
Thanks guys for the info. I ran across what I thought was a fair deal ($150) on a 9" with 411 gear and spool, guy was running it in a S-10 at the track. Thought I might try to make it work in my luv, 327 5 speed. Thanks again.
PostPosted: Thu May 17, 2007 10:09 am
At that price, I'd grab it, you can always find a posi later.
PostPosted: Thu May 17, 2007 12:22 pm
LUTIT now that's some funny s#%t! :smt005, low budget just hope you don't have to push it while turning either, it's a bitch the more you turn.
PostPosted: Fri May 18, 2007 3:17 pm
I agree by it ,hell the gears a lone are that much plus now you have a carrier and a spool ,then sell the spool to help by a posi.. 8)
