It is currently Tue Jun 30, 2026 5:59 am
 Post subject: 81 Pup diff into 80 Luv
PostPosted: Sun Apr 29, 2007 5:29 am
Australian LUV Guru
Will a 81 pup diff go into my 80 Luv?
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sun Apr 29, 2007 11:20 am
should fit fine, I think the whole truck is pretty much the same thing.
Resident lurker
PostPosted: Sun Apr 29, 2007 12:00 pm
There definately are some differences between the two. I'm in the process of merging a '75 body with the running gear from an '82 diesel. At first I was going to just move the body and bed from the '75 over to the '82 but quickly found that the bed mounts differently. If I find the same with the cab, I might look at moving the running gear from the '82 into the '75 chassis but I was hoping to keep the disc brakes and upgrades that were made between '75 and '82.
Anyhow, not sure on the differential. I can go make some measurements if it would help you. Also, note that the '81 wheelbase is 2" longer. That might just be in the drive line but it also might translate into differential differences. I'll go look again.
Good luck,
Eric Q.
My build thread.
PostPosted: Sun Apr 29, 2007 7:56 pm
time to reread. :oops: 81 -80.
I do think the chunk will fit though, but the trucks are far from being the same :oops:
Resident lurker
