PostPosted: Fri Apr 27, 2007 11:56 pm
Australian LUV Guru
Has anyone fitted a remote shifter out of a newer model to their Luv? :?:
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Sat Apr 28, 2007 12:04 am
I have a console B&M shifter from a Mercury Capri . There isn't to much room between the seat and shifter hump.
PostPosted: Sat Apr 28, 2007 12:13 am
Australian LUV Guru
I'm talking about a shifter for a manual gearbox, the setup i have seen bolts to the original stick location and via a linkage moves the stick back closer to seat and gives shorter throw
PostPosted: Sat Apr 28, 2007 8:59 am
so you buy the one on ebay ? first one i have ever seen
PostPosted: Sat Apr 28, 2007 9:55 pm
Australian LUV Guru
My bud pulled it out of a newer mod Isuzu, unsure what called in U.S maybe Hombre, Trooper.
PostPosted: Sun Dec 16, 2007 3:12 am
Australian LUV Guru
Heres a pic of a remote shifter, this would be cool in a Luv or Pup. They are a popular mod done to gemini/ I marks here in Australia.
PostPosted: Sun Dec 16, 2007 12:52 pm
i have that one but my starter is on the passenger side i got it out of a 89 pup and i also got the rearend
dangerous-toys4life
75 k-5 2x
94 king cab
 Post subject: remote shifter
PostPosted: Tue Dec 18, 2007 12:45 am
Is the remote shifter, the rubber boot that you guys are talking about?
If that's the case, I used a aftermarket one from Kragen Auto, it worked good, it came with a chrome square ring that you screwed down.
PostPosted: Tue Dec 18, 2007 1:48 am
It's under the shifter boot...
PostPosted: Tue Dec 18, 2007 6:00 am
PITA Old Fart
Well uncover the darn thing and let's have a look at it...lol
 Post subject: Re: remote shifter
PostPosted: Tue Dec 18, 2007 2:45 pm
No. If you look at the pic carefully, you see where the stick should go into the trans. But there is a mechanism there that travels back a few inches, and the stick is in there. It is a mechanism that moves the shifter back so it will come up through the floor in a different spot.
PostPosted: Tue Dec 18, 2007 4:31 pm
The 5spd I pulled from my Impulse parts car has this gizmo on it. I have considered putting it in my 77 when I swap the trans in, but not sure I want to have to reach back beside me to shift. Its not like the I'm really reaching far in the LUV to shift anyway. But, I figured I'd measure it out before I decided anything. I'll try to snap a few pics of it this week.
PostPosted: Tue Dec 18, 2007 6:28 pm
Well you can see in that pic, that the shifter is pointed back towards the front so you can reach it. :lol:
I don't see a need for it in my stuff, either. I'm sure there are applications where it makes a lot of sense though.
PostPosted: Mon Jan 07, 2008 9:16 am
The Impulse one is too far back. It can be shortened.
The one off the box in the picture sort of does fit but its doesnt.
The Box its on is the later model MUA transmission as opposed to the MSG box in the luv and impulse and pickup with a 2.3L or smaller.
The shifter quadrants have different bolt spacings. Reason being that the on the early transmission the mounting face slopes down at the rear, on the later MUA trans its flat and parallel to the main shaft in the box.
So if you modify the bolt pattern and space it up so the back of it doesnt hit the rear extension housing it can be made to fit.
You would be better off with a column shift quadrant and an aftermarket linkage type shifter.
Bob.
