It is currently Thu Jul 02, 2026 1:29 am
 Post subject: G200
PostPosted: Thu Mar 08, 2007 11:34 am
What exactly is a G200 motor and how does it differ from the standard 1.8 Isuzu. Is the G200 a better motor, what did it come out of? Will everything interchange from the 1.8
PostPosted: Thu Mar 08, 2007 12:43 pm
The G200 is just a slightly bored out version of the G180 that came in the LUV. Externally they are virtually identical, and all outside parts, brackets, etc will bolt up in the same place. Basically think stock LUV 1.8L motor with more displacement.
As for what it came out of, Isuzu pickups after 83 and up to 86 or 87, Troopers 84-85, and non-turbo Impulses up to 87. The Impulse version uses flat top pistons for a bit higher compression but is otherwise the same.
Users browsing this forum: Google [Bot] and 32 guests
