It is currently Thu Jul 02, 2026 9:39 am
PostPosted: Thu Mar 01, 2007 8:47 pm
particularly a non-GM trans.
i got access to a rebuilt iron case mopar 833
any swap kit available,advance adapters maybe?
PostPosted: Thu Mar 01, 2007 11:26 pm
i don't see how it could be all THAT hard. i believe the A833 was an option on the early 80's gm FULL size trucks. i think the 1 tons specifically. maybe if you could get a bell from one of those. and somehow adapt either a mech. linkage or even a hydraulic one. it might just work. just too much hassle IMHO. they are good transmissions though. an M22 would be probably just as good and probably easier to mate to a SBC. it's the input shaft length and diameter that i'd be worried about. that and the clutch. i don't know too much about dodges. have you tried the chevy truck board? i know there are some pretty knowledgable people there. IIRC joel rosen put one of those transmissions in a 2nd gen camaro. it was pretty weird seeing a mopar pistol grip shifter in a '81 camaro. good luck.
edit.. i just forgot about lakewood. i think i remember seeing a bell on there site. let me check. found a lakewood bell for a ford toploader to a SBC. sorry bro.
front tires are overrated.
Last edited by mightymouseman on Thu Mar 01, 2007 11:41 pm, edited 1 time in total.
PostPosted: Thu Mar 01, 2007 11:36 pm
this isn't the "hemi" version its the regular iron case non-OD version,still really strong though
the muncies and the t-10's are strong but the factory aluminum cases are the weak link.a toploader is strong too but i'm not putting a ford trans in my truck :lol:
PostPosted: Thu Mar 01, 2007 11:51 pm
Keeping the bolts torqued and checked on the aluminum housings will help em live. I've got a M22 out of an old pro stocker with the Doug Nash pro gears. I've never replaced the case, Just 1 set of synchros and 3 sets of shift forks in 20 years... :lol: TransDapt might be able to help if you want to use the iron lung.
PostPosted: Fri Mar 02, 2007 7:53 am
You mean i might have problems with my T-10? I DON'T THINK SO. But again i will say it "some people can tear up an anvil with a feather" if you are one then go auto.Now for your question the mopar trans has a lot longer in put shaft then a GM so you will have to locate an adapter to get it to fit and good luck.And a alum.trans will hold up just as long as that HEAVY iron trans will and you can shift them faster as well.
PostPosted: Thu Mar 08, 2007 12:56 am
mcleod has a modular bell. you might be able to piece something together there. i totally forgot about those guys. i haven't messed with a stick shift swap in a long time.
the mcleod modular bell site
http://www.mcleodind.com/Application_Gu ... USING.html
hope that helps. looks like it might work. i'd be worried about the clutch disc and flywheel setup. and the actuation. good luck bro.
Users browsing this forum: Bing [Bot] and 32 guests
